Please need advice asap!
12 replies to this topic
  • panteramatt
Posted October 15, 2004 - 12:57 PM
I have a chance to get either a yzf400 or 426 motor to put in my 400ex frame. Which one would beb better for an atv or is there much difference? Whats the biggest bore that a 400 can go to and be reliable?
  • sirthumpalot
Posted October 15, 2004 - 02:22 PM
The later the better.
  • panteramatt
Posted October 15, 2004 - 08:08 PM
Why is that, I need some info.
  • Chipstien
Posted October 15, 2004 - 08:16 PM
More cc's and a better clutch. Bigger radiators too if you are getting them with the motor.
  • panteramatt
Posted October 16, 2004 - 04:39 AM
But cant a 400 be bored out just as much as a 426?
  • SureBlue
Posted October 16, 2004 - 04:56 AM
But you asked:
"I have a chance to get either a yzf400 or 426 motor to put in my 400ex frame".
Why would you then chose 400 and bore it up if u can have 426? :cry:
  • panteramatt
Posted October 16, 2004 - 05:08 AM
Heres the deal. I have a 250r and a 400ex rolling chassis. I can get a 250r frame with a yzf400 motor already modded and ready to roll, or can get a good deal on just a yzf426 motor and have to mod my 400ex to fit and buy some other things.So please help me out!
  • Fastest1
Posted October 16, 2004 - 05:10 AM
What year 426 motor? The 2001 and later has a splined crankshaft snout, whereas the 2000 and earlier have a keyway for the counter balancer gear, Yes a 426 jug and piston will fit a 400. Better carb on a 2000 and later model too.
  • panteramatt
Posted October 16, 2004 - 05:32 AM
OK, will a 2001 and later carb bolt directly onto a 98-00? Also I see a wiseco 444 kit on ebay that comes with the cylinder, piston and all for the 426, will that bolt directly onto a 400
  • sirthumpalot
Posted October 16, 2004 - 10:03 AM
I think the rods changed at some point, but I don't remember what year?
  • panteramatt
Posted October 17, 2004 - 06:23 AM
Anyone else, I need some info.
  • SFO
Posted October 17, 2004 - 09:24 AM
426 gets the larger id rod small end.
426 rod less prone to shed its small end than a well used 400.
400 has a closer first and second gear which results in a closer ratio gearset for the 400 which might be adventageous for the 4wheeler.
Upgrade the rod to a failcon for a stroker cr-f and get the bushed small end.
A 97 mm kit will require fittment of the 426 rod, or the above falicon choice.
I would rebuild any motor before fittment, as there is no gaurantees.
  • SXP
Posted October 17, 2004 - 09:17 PM
SFO - What's the end cubic capacity after the CR-F stroker and 97 mm overbore? Thanks.
  • Hot  113 replies
  • Hot  47 replies
