Edelbrock
1 reply to this topic
  • Spacehog
Posted June 27, 2002 - 08:20 AM
I have now got my Edelbrock fitted on my 650R and the performance is superb.
But it idles really slowly til it's warmed right up.
I know you can speed it up on the adjuster but this is a bit of a pain.
Also what is the starting procedure from stone cold?
cheers
  • qadsan
Posted June 27, 2002 - 09:37 PM
When I start mine from stone cold, I simply give the throttle a few quick twists causing the pump to squirt some fuel, then I find TDC and kick smoothly all the way through. She usually fires first or second kick for me when stone cold. I do not use the enricher lever, nor have I ever tried it. You must twist the throttle quickly to get the pump to work, otherwise it returns the extra fuel to the bowl.
