xr600 axle diameter
5 replies to this topic
  • WebCrush
Posted June 27, 2002 - 07:52 AM
Anyone know the front axle diameter for a '95 XR600?
Thanx
  • Moredesert
Posted June 28, 2002 - 05:31 PM
The best I can tell it's 12mm. I don't have a 600 anymore but I do have a set of rear wheel bearing on the shelf. The drive side that takes the spacer is a 6204 and the brake side is a 6203. The ID is the same size as the axle and that works out to be ~.670/in or 12 mm.
  • Moredesert
Posted June 28, 2002 - 05:37 PM
Sorry you said front axle :) Same thing the front bearings are 6003 and is also 12 mm
  • WebCrush
Posted June 28, 2002 - 07:22 PM
thanx, but i just found another source and it states 17mm just like the xr400.
you sure you measured right? :)
  • Terrain Rider 4z
Posted June 28, 2002 - 08:55 PM
There are about 2.56 cm in one inch, if you convert that to mm you get 25.6 mm. Multiply that number by .67 and you should get 17.152 mm. :)
  • Moredesert
Posted June 29, 2002 - 07:45 PM
Well I'll be. :) :D I took the caliper and compared it to a metric tape measure. I guess I can't see stright. Like I said 17mm. :D :D :D
  • Hot  186 replies
  • Hot  29 replies
Honda XR650L 2016
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
