Passenger Pegs
6 replies to this topic
  • Danco
Posted June 26, 2002 - 06:20 AM
Does anyone know where I can get some passenger footpegs for my 650R? I saw the ones that come on the L model and would like a set for my R. Is any welding necessary to put them on? Thanks
  • voodooridr
Posted June 26, 2002 - 06:39 AM
The "L" has threaded bosses welded into the frame for the brackets to bolt to.
The pegs would probrbly work if you can supply some place to bolt to.
  • Denali
Posted June 26, 2002 - 10:39 AM
To add to voodoordr coment...
I have a XR650L and I lost one of my passenger pegs and had a hell of a time trying to track down a NON-OEM provider who will not throw me over the coals on price. You will have to weld on a bracket to hold the pegs on but the hard part is finding the pegs.
I called the folks at www.fourstrokesonly.com who had said they've got a guy who is making them after market which would include the bracket. Outside of Honda look for DR350 passenger pegs on ebay. I've heard with a little adjustment you can get them to work...
Good luck...
  • voodooridr
Posted June 26, 2002 - 01:01 PM
Also check MSR they make a set of add on buddy pegs that look like a direct copy of the "L" pegs.
http://www.msracing....parts/dsdb.html
  • Brian_Heath
Posted June 26, 2002 - 01:38 PM
MSR and Baja Designs will have them. You will have to weld a plate. So far I took my wife on a lot of single track and it was pretty fun except for the long rocky down hills. It is like trying to work the remote while doing pushups with some one setting on your back. They are holding up fine. And two bolts takes them right off. There are also the cheap ones that just clamp on around your swingarm.
  • Craig_Mitchell
Posted June 26, 2002 - 07:59 PM
Danco, a word of caution bud. I recall
reading in either the owner's manual or the
shop manual that 100kgs is the recommended
max. weight. Even with a better spring
I personally would worry about some of the
linkages breaking as this happened to me
on a previous bike with my small kid aboard.
cheers, Craig
  • Danco
Posted June 27, 2002 - 06:51 AM
Thanks to all!!!!
Honda XR650L 2017
  • 0 reviews
Honda XR650L 2016
  • 0 reviews
  • Hot  60 replies
  • Hot  35 replies
  • 9 replies
