2004 WR 450, broken chain bent shifter lever shaft, oil leaked out
2 replies to this topic
  • fishwar
Posted October 12, 2004 - 04:19 PM
On a 2004 WR450 does anyone know if you can replace the shifter lever shaft and shifter shaft oil seal without splitting the cases? :cry: :cry: :cry:
  • Gadsen
Posted October 12, 2004 - 05:56 PM
Well, I have torn down a few bikes and the shifter shaft slid out from the clutch side, but it required removing the clutch basket. I assume its the basic same deal, but it may not be either. I bet you could look at the part exploded veiw from the Yamaha site and determine.
  • fishwar
Posted October 13, 2004 - 02:49 PM
Thanks Toyoda, your right the shift lever shaft can be replaced from the right side cover and removing the clutch. I was sweating it. I thought I had to split the cases. Thanks for the info.
