DRZ - S Head Pipe VS. DRZ - E Head Pipe...Does E Produce More Power???
7 replies to this topic
  • wynn
Posted October 12, 2004 - 01:40 PM
I have a 2004 DRZ 400s with a CHM Pipe on it. I'm being told that if I were to put on the "E" model head pipe, it would produce more power. Is this true? There saying the "E" model has a bigger diameter which will produce more mid to top end. Please give me your thoughts on this.
  • Z4You
Posted October 12, 2004 - 01:56 PM
your CHM Pipe must be a slip-on, if so a E h-p will not fit it! but a E h-P is a better starting point then a S h-p for sure! so with that said I think you should Buy A Full System Yosh or just ride it til you dent it then buy a Full System from of any brand from the TT Store Good Luck :cry: :cry:
  • psych_ward
Posted October 12, 2004 - 03:06 PM
the 400e pipe is to short to fit the drz 400s, I know because that was the first system I recieved from the dealer. I had it all on and wham like 1-2 inches short of the mid pipe to the head pipe :cry: I put the right system on and am thrilled with it. Full yosh and jet then air box is the way to roll before doing things like cams and bigbore stuff :cry: :cry:
  • wynn
Posted October 12, 2004 - 05:44 PM
My CHM is a slip on but it goes all the way up to the collector. CHM makes a pipe for the E and and pipe for the S. The only difference in the two is the size of the collector opening. The E is a bit bigger.
It doesn't make sense to me that the E would be shorter then the S from the motor to the mid pipe....it's the same engine. :cry: My buddy works for CHM and he said he would take my pipe back, cut off the collar, and re-weld the E collector on if I find out that it will perform better with the E head pipe.
Will it perform better???
Is the E head pipe really shorter then the S head pipe???
  • Eddie Sisneros
Posted October 12, 2004 - 05:57 PM
the E head pipe is the same length,but 3mm larger.
does make more power.
imho even the E head pipe leaves alot to be desired.
  • wynn
Posted October 12, 2004 - 06:24 PM
Thanks burned.........you the man! :cry:
  • Thumper1984
Posted November 04, 2005 - 04:39 PM
Hey, i just bought a US 2006 DRZ400S, will the 05' exhaust systems fit a 06' ?
Also, will a E model headpipe fit on my 06' S ? more power ?? :banghead:
  • Neil Claydon
Posted November 04, 2005 - 05:06 PM
The "E" header pipe will as Burned has said fit, and should make more power, and is a fairly easy mod.
You will have to find (or make) an adaptor to join the two together.
I am using an FMF PowerBomb header (bigger bore than either the "S" or "E")
This has been used with the following to date, standard "S" silencer, this made a marked improvement to performance, next I drilled the end plate on the standard can, no improvement but sounded more like a motorcycle.
Then a Leo Vince Titanium slip on system followed, this was very noisy and made very little improvement to power, in fact it lost some in the lower rev range. I then fitted a decibel killer, this gave some bottom end back without affecting top end.
After bending the Leo Vince system I obtained a nearly new (10 miles) exhaust from an "E" (from a fellow TT'er, thanks Darrenp1), after making a sleeve to make it fit the 41 mm diameter FMF header (Alloy bar, bored to 41.1 mm and 47 mm diameter on the outside to fit the "E" can) I find that over all it performs better than the Leo Vince, which was a pleasant surprise, but not what I was expecting.
The header will give a better power gain than a slip on in my experience.
I think that the "S" system in the states is a more open exhaust than the UK "S" (Burned would be able to confirm this) and I would expect that on a nearly stock DRZ (just the 3x3 and D/Jet) it is probably all you really need.
Neil.
:banghead: :banghead: :lol:
DRZ400s front fender swap for highway? by webbie1
  • Hot  35 replies
Suzuki DR-Z400SM 2016 by kiwi-on-wheels
  • 9 reviews
  • Last review by E2Moto
  • On Yesterday, 10:42 PM
DRZ400 tank, help me decide which one by MEANDMYDRZ
Prepping for long road trip - What have I overlooked? by webbie1
  • Hot  33 replies
Bike Enthusiast Youtube Series by Davnic
Street   General Street Bike Forums   General Street Bike Discussion
  • 2 replies
