Convert single filament taillight to dual filament (KLX300 & 650R)
1 reply to this topic
  • kawboy373
Posted October 12, 2004 - 08:11 AM
Is there a quick and easy way to convert the stock taillight assembly to accept a dual-filament bulb (for a street conversion)? I realize I could buy a new taillight assembly but my goal is to save money and keep as much of the stock bike as possible.
Thanks.
  • Bill_P
Posted October 12, 2004 - 08:59 AM
Yes, it's a piece of cake. You need to go to your local auto store (I
went to pep boys) and get a dual filament socket and bulb and go
here
to get a brake switch -
http://www.fourstrok...keSwitches.html
Your new socket will have 3 wires hanging off the back. I hope I say
this right cause I'm not a electronics whiz, but I know the basic gist
of it:
It's so much easier to draw a picture, but I'll try to put it into
words. There will now be 3 wires coming out of the new socket (In
my
case it was two blacks and a white) and two old wires coming from
the
front of the KLX back towards the old tail light housing. The two
wires
that go back to your current tail light do the following:
One KLX wire goes to the ground wire coming out of the socket. (In my
case - the white) It will probably be one color and the other two
wires will be a different color. I hooked the white up directly to one
of the two wires coming from the front of the bike. Then the other KLX
wire needs a "Y" connector on it. One side of the Y gets hooked up to
the other KLX wire that went to the old tail light - the one coming
from the front of the bike. The second leg of the Y will go to another
of the 3 wires - one of the colored ones (in my case a black.) Which
black is the trick. You may have to switch them around as mine weren't
marked. One is for the running/on light and one is for the brake
light. The 3rd leg of the Y goes down to your brake switch on the rear
cylinder. In one side, out the other side and back to the tailight to
the last wire (the second black in my case) of the new socket.
I'd suggest those bullet type connectors. The kind that have plastic
sealing all around them and that press fit tight (the above site will
have them). Also, I personally solder the connections instead of
crimping them - on a dirt bike you'll find they will be much more
reliable. If you can't discern how to do it from this description, I
can probably draw you a pic and send it. Good luck - it's pretty easy
and a lot cheaper than a DS kit.
Bill
New bike by Aceinyoface
  • Hot  43 replies
Knobbies Breakin' Loose by Bumpy Bikes
  • 0 replies
Abandoned Barn by Bumpy Bikes
  • 2 replies
Bumpy Bikes #57 by Bumpy Bikes
  • 0 replies
I'm defintely 1st to make animation-style riding clips using that new app by Bumpy Bikes
  • 0 replies
