Rear Suspension--stiffer spring/shock?
4 replies to this topic
  • XR650R_Bob
Posted October 11, 2004 - 05:03 AM
I'm trying to stiffen up the rear suspension...it has a lot of sag when I load up the rear rack and bags. In getting ready for a long road/backroads trip I want to be able to carry enough gear for a week or two. Right now the suspension looks like it is at the end of the adjustments and it still sags about 3 to 5 inches when loaded up. I also tore up the lic tag with the rear wheel without any load...just doing backroads. The suspension is just too soft.
I'm 6'4", 225lbs.
Any suggestions? :cry:
  • tirebiter
Posted October 11, 2004 - 05:48 AM
Check with RaceTech. Fill out the info for your bike, weight and type of riding. They'll recommend the correct spring rates.
http://www.racetech.com/index.asp
  • XR650R_Bob
Posted October 11, 2004 - 09:46 AM
Thanks, I'll check them out.
  • drex
Posted October 12, 2004 - 09:12 AM
You should also check out Bruce's info here:
http://www.borynack....650R/xr650r.htm
  • TimBrp
Posted October 12, 2004 - 11:53 AM
I would at least reccomend an 11.0kg to 12.0kg spring loaded up.
