A little help
3 replies to this topic
  • billyboy11b
Posted June 02, 2002 - 05:57 AM
Just got my motor (93 XR650L) back after it sitting almost three years in the shop (Military can be a bitch that way)I got it back together, but it won't star and run for more than thirty seconds. After a great deal of cranking, it began to blow oil from the crank breather hose, and the timing access port. This totally blew my mind, I have worked on bikes on and off for a few years, but never seen anything like this. Any suggestions on how I can get going again would be appreciated.
  • loufish
Posted June 02, 2002 - 06:25 AM
Maybe a stuck ring, allowing a lot of blow-by into the case. Have you cleaned out the carb? I don't mean just draining and re-filling with new gas, you need to take it all apart, and clean it out with carb cleaner(what else?) and blow out all the passages with compressed air.
  • billyboy11b
Posted June 02, 2002 - 04:33 PM
I cleaned the Carb with carb cleaner and compressed air. I also checked to insure that spark was present. Still no dice.
  • Moredesert
Posted June 02, 2002 - 07:13 PM
Go back to basic's. Check the valve timing and gap. Check the compresion.
The oil is a mystery to me. I guess you could have a stuck ring. It all depends on what kind of work was done to the engine. If you had the engine a part did you get all the oil pump o-rings, seal in place. You might be hoseing the inside of the crank case causing oil to spray threw the breather tube. :)
