Graphics Kits
6 replies to this topic
  • Greg_C
Posted July 01, 2001 - 03:42 PM
The Wife is letting me get a new seat/tank combo for my B-Day. (Even payed for half)
I ordered the Clarke tank (blue) and the IMS seat (SDG is up to $93, & I like the blue) :)
I wants to get some graphics for the tank and rad shouds but don't know what will fit the 3 Gal. tank. The YZ stickers look too small.
  • Mr_Toyz
Posted July 01, 2001 - 08:36 PM
If I understand you question correctly. Any YZ graphic will fit the Clarke tank just fine. They dont look to small.
  • Greg_C
Posted July 02, 2001 - 10:12 AM
Ok, I just placed an order for a Factory Effex Graphic kit. Now I need to figure out the best way to install them. I have been searching the archives and it looks like hair dryer and solvent to remove old sticker, then wash with soap and water, then a 50/50 mix of water and rubbing alcohol to install.
Let me know if I am missing anything.
I read a tip on one of the sites I was shopping at and it said to ride the bike for at least 3 days before installing the graphics to let the vapors help get the plastic ready for install. Does this sound correct I read contradictory posts on this here at TT.
Thanks Greg C.
  • mcarp
Posted July 02, 2001 - 10:55 AM
Your right on. I would caution against using the solvent (ie brake cleaner) until you've tried the hairdryer. WD-40 would be a better choice. Solvent generally dulls the finish, OK if the graphic is hiding it, but not so good looking if it's exposed.
70/30 water/rubing alcohol works real well. Spray both the part and sticker.
Yes, let the tank have maybe 2-3 weeks to vent first.
Sounds like you've got it covered!
  • Greg_C
Posted July 03, 2001 - 03:35 AM
Cool, Thanks for the input.
  • Bill
Posted July 03, 2001 - 03:54 AM
Hey Greg,
I just installed graphics on my bike. I used Windex and a bondo spreader. I squirted the windex on and squeegied the windex out. They stuck great and no bubbles.
99 WR400f, YZ timed, MX-Tech suspension, Scotts steering damper, White Bros E-Series (12 discs), tapered header and a/f. Kouba T-handle for the fuel screw. Works Connection billet throttle tube and frame guards. Cycra Pro-Bend, triple clamp mount handguards. Thumper Racing rad guards, Renthal Jimmy Button highs, YZ Tank and IMS seat, YZ number plate, odo removed, EKP, 48PJ, 175MJ at 500-1000' Thanks James Dean!
  • Mr_Toyz
Posted July 03, 2001 - 07:30 AM
Hold the presses. I consider my self a pro... :) all that stuff works ok but I'm telling you nothing works better than a bath tub and some hot water. You can stick and unstick the graphics as may time as you want...
