How hot is hot?
7 replies to this topic
  • WH
Posted October 08, 2004 - 06:48 AM
I have a 2000 Wr400. Purchased a few months ago. Replaced the stock muffler, which was gutted, with a IDS Supertrapp. I am currently running 16 rings. It starts and runs great. I have noticed when it gets dark outside the head pipe has a slight red glow. I checked the spark plug and it looks good. Is the engine running too lean? :cry: Should I rejet it? We are just a couple of hundred feet above sea level.
  • SXP
Posted October 08, 2004 - 06:57 AM
Normal, normal, normal :cry:
  • jhteneyck
Youre fine - that is normal. My bike, wr450 does the same thing. Once you start moving it will cool down a bit.
  • StreetbikePimp
Posted October 08, 2004 - 08:11 AM
Perfectly normal.
The head pipe is only a single wall pipe to save weight. Typically, most four-stroke head pipes are dual wall, so you don't see it glowing.
  • 5valve
Posted October 08, 2004 - 08:48 AM
I noticed the same "problem", the pipe was badly hit and I thought it was overheating from reduced flow...fixed the problem, but pipe still glowing :cry:, untill I was told it is normal
at least pipe looks good now :cry:
  • WH
Posted October 08, 2004 - 04:23 PM
  • YamahaWR450FMike
Posted October 08, 2004 - 05:37 PM
well with all that high compression and fire coming out of that pipe yes of course it's going to glow red hot.
  • Chevy_Cowboy
Posted October 09, 2004 - 01:49 AM
not only is it perfectly normal but its a pretty cool feature IMO.
I get a kick out of firing it up at night and showing off my glowing pipe :cry: :cry:
