CA smog block off
1 reply to this topic
  • billyj7175
Posted May 22, 2002 - 08:46 AM
I did a homemade smog block off kit, until the actual thing arrives. Basically I left the two hard pipes attached and plugged them, and then plugged the intake port and the airbox port. I can't really tell any difference in power, but it is noticeably harder to start hot or cold. Does removing this lean out the mixture in any way? Will I need to re-jet?
  • XRider
Posted May 23, 2002 - 08:12 AM
I jetted my 650R before I added the block off kit and it ran better. I ordered a Clarke 4.3 tank and it required me to add the block off kit. Now the bike runs even better. I am running:
175 main jet
68s pilot
Competition needle
Larger intake manifold
Bill’s pipe
And Uni air filter with both restrictors removed from the air box.
I never used more half choke since and it usually starts on the first kick.
