02 426 wont start hot..new to strokers
8 replies to this topic
  • fat_oil_can
Posted October 07, 2004 - 08:04 PM
Hello,
New to the 4-stroke thing here...i have an 02 426 and it is a great bike when it runs..my biggest problem is starting after it is hot...I have done the carb mod and the blue wire trick and cleaned the carb a few times and always keep a clean filter..It runs like a striped ass ape and startes on the first few kicks when cold..But when shes hot you might as well have a 12pack and watch a ball game because it does not want to re-fire..i have tryed all the tricks on starting..But the bottom of my foot just turns black and blue..Any help would be great..Thanks
  • yamaha.dude
Posted October 07, 2004 - 11:19 PM
Welcome to TT...
Sometimes the hot start (the red button on the carb) can be a hindrance... sometimes I just start it without the hotstart... But I have the 450 cam in my bike, so I just kick it until it fires... Try not to touch the throttle at all when starting, hot or cold...
Good luck,
David
  • sirthumpalot
Posted October 08, 2004 - 02:53 AM
Are you using the hot start (red knob)? That typically makes hot starting 100% easier.
  • ripntear
Posted October 08, 2004 - 03:58 AM
Could possibly be that your pilot jet is too lean. What size do you currrently have in now? What's your altitude and temp? Check out this site http://motoman393.thumpertalk.com/ under Tech Articles go to Engine then YZ426 Jetting & Tuning spreadsheet.
ripntear :cry:
  • SureBlue
Posted October 08, 2004 - 07:49 AM
Provided the jetting is correct, my experience is to ALWAYS use hotstart and NEVER touch the throttle when the bike is hot. JMO.
Edited: Adjust the idle higher too, it may WANT to start but does not have the rpm's needed to get it going.
  • Fastest1
Posted October 08, 2004 - 03:34 PM
Maybe a little more info would help too. Like where are you in altitiude? Has it always done this or is it a new problem? Has the temperature changed recently (getting cooler)? Fresh Plug? Type of gas? Have you adjusted the fuel screw? Do you adjust it daily? Thanks
  • YZDAD1
Posted October 08, 2004 - 03:44 PM
Check the valve lash & lean her out! :cry:
  • TheRainMan
Posted October 08, 2004 - 05:08 PM
I have a hard time starting my 02 426. Runs good cold, put if I drop it in a turn/or crash, the bike wont restart. Runs good for about 10minutes then its tries to die in the low rpm range. I've ridden 2-strokes for 20yrs and have only had this bike a month and think its time to get rid of it. I'm tired off kicking this ungrateful mule! Good Luck!
:cry:
  • sirthumpalot
Posted October 09, 2004 - 05:43 PM
:cry:
Sounds rich to me, turn the fuel screw in a tad. These things are very reliable starters once you learn how to do it. :cry:
  • Hot  28 replies
  • Hot  50 replies
  • On January 15, 2017
  • 10 replies
