have i been mis-timing my bike all along?
5 replies to this topic
  • tool
Posted October 07, 2004 - 12:59 PM
so, im doing a rebuild and flipping through the manual, in which i see that your supposed to line up the little I on the flywheel with the cams.
i have been lining up the mark on the left of the I, which somewhat resembles an H, with the cams. i cant see how i could be wrong about this - my engine has always run fine with good power. the manual is fairly clear which mark to use, and its not the H.
how is this possible? :cry:
  • yzf_rider400
Posted October 07, 2004 - 01:44 PM
don't know. I'd re-align it with the "I" if you have not done so already. I had the joy of replacing my timing chain because I jumped cam-timing and had to go through the ordeal of lining up the cams and "I" too. :cry:
  • TimFurryBalls
Posted October 07, 2004 - 02:02 PM
While re-camming my '02 I had no idea what friggin' "I" the manual was talking about! There was only a few small dashes about a couple mm's in length, not some big "I" right across the flywheel like the manual shows! :cry:
  • YZ250F_Rider
Posted October 07, 2004 - 02:05 PM
LOL yeh I hear that. It's the vertical dashes.
  • yzf_rider400
Posted October 07, 2004 - 03:07 PM
I hear that, it took me a bit to figure out where the "I" was. Now that I know it's by the "H" it's not a problem to find it.
Posted October 07, 2004 - 10:03 PM
Keep in mind that the 'I' (top dead center) and the 'H'(timing marks for timing at idle) are only about 6-8 degrees apart. Ten dgrees of crank rotation causes only 5 degrees of cam rotation. The cam sprokets have 32 teeth, meaning that to move a cam one tooth is to rotate it 11.25 cam degrees. So, in order to move the crank far enough to move the cam one tooth out of place, you would need to move the crank 22.5 degrees.
So don't worry about it. If you had a cam that far out of time, you would know. :cry:
  • Hot  30 replies
  • Hot  38 replies
  • On January 15, 2017
