lighting my yzf400
5 replies to this topic
  • bansheefreak
Posted October 06, 2004 - 05:57 PM
what do i need to do to my yzf400 motor to be able to run lights??? i have it in an atv and like to ride at night in the dunes...
  • Motoman_AZ
Posted October 07, 2004 - 02:52 PM
There isn't an easy (cheap) solution for the YZF.
http://www.rickystat...ng systems.html
http://www.bajadesigns.com/
and there are a few others. The YZFs don't have a stator in them to support battery and lighting. You have to buy the conversion stator and a lighting kits. Which makes the price double of other bikes.
Let me know if you find a kit under $500 for everything.
  • PumpkinHumper
Posted October 07, 2004 - 05:29 PM
You need to call www.electrexusa.com For $300 you get a wr stator and flywheel that will work with the yz CDI. All you then need is a headlight and voltage regulator. Maybe $100 for both. The stator puts out 130 watts.
  • bansheefreak
Posted October 07, 2004 - 07:54 PM
well i'm not looking to spend 500 bucks for lights... so i have a spot for a mc battery ,,, how long do you think lights would last on a battery with no charging system????
  • bansheefreak
Posted October 18, 2004 - 08:57 PM
bump
  • PumpkinHumper
Posted October 19, 2004 - 07:59 AM
I really wouldn't go the way of the batery. If there is any way possible go with the lighting coil. It is so much better in hte long run. I tried to go the cheep way before I got this coil and ended up with the wr setup. Look around sometimes you can find them used here or on e-bay.
And new it wouldnt be $500 for the stator/flywheel/headlight/voltage regualator. Probably just under $400. and if you shop around for a used stator/flywheel maybe you can stay under $300
  • Hot  113 replies
  • 5 replies
  • 10 replies
