raising fork in triple clamp?
3 replies to this topic
  • InChanWeTrust
Posted October 06, 2004 - 12:55 PM
How do I raise the forks to get a better turning bike? Is it as simple as loosening the 4 bolts per side and sliding the tube up? Mine won't slide and I don't want to put any wd in there for fear of the forks being hopelessly twisted on my next get-off.
Chan
  • BWB63
Posted October 06, 2004 - 02:24 PM
If you remove all eight bolts and stick a flat screw driver facing down in the slots of each clamp....a little tap add they will stay. now the tubes will fall out....if you do one side at a time (just two screw drivers) it won't move so freely and you can get your 5mm from the bottom of the cap to the top of the top triple clamp.
  • BRP27
Posted October 06, 2004 - 04:10 PM
How about a report on how the bike handles with the front lowered. Turns faster? Less Push (slide) on the front wheel? Less stable at speed?
  • InChanWeTrust
Posted October 11, 2004 - 05:41 PM
I had trouble raising the forks because the clamp that holds the fork boots was tight. Anyway, I raised the forks about 1/2" or 12-15mm, it rode much better. Turns great, stable at speed up to 65 (max I got to). I rode a turkey run in CT (Rock Run), not sure if it was the good breakfast, staying well hydrated, looking far ahead on the trails or what, but as an inexperienced rider, I was keeping up with and passing other riders. I had a great time. The only other thing I did was to set all clickers to the soft side of factory spec (per manual). You can see how the bike is set up below.
Chan
  • Hot  35 replies
Honda XR650L 2017
  • 0 reviews
  • 2 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 22 replies
