Uni Filter oil
4 replies to this topic
  • billyj7175
Posted May 03, 2002 - 11:47 AM
Uni Filter states that you must use their filter oil and filter cleaner....anybody used anything else?
  • neWRiver
Posted May 03, 2002 - 12:14 PM
Yeah, I use no-toil oil and cleaner and the filter fell apart.
  • needsprayer
Posted May 03, 2002 - 02:24 PM
Billy,
Don't know about the UNI filter. I am happy with the stock one. I clean it every three rides and no dirt has gotten past it into the airbox.
I used to use gasoline, outdoors and and in a shallow pan. This is not safe and it destroys the adhesive holding the two layers of the stock filter together.
Now I soak the filter with Dawn dishwashing detergent and cover with very hot water (in my stainless steel kitchen sink). I let it sit a while and then knead the foam with my fingers. I roll-up (do not twist) the filter to squeeze out the dirt. Repeat a second time and it is clean.
Let the filter dry. Spray with filter oil then roll up filter in both directions to spread oil out evenly.
This takes a little longer but works great. That's why I have two filters and do this at my leisure. No expensive treatment solutions are required.
  • Jim_Scheide
Posted May 04, 2002 - 03:12 AM
Great idea with 2 filters!! That way one's always ready to go! I do that with chains too, & it spreads the use so your sprockets/chains last longer. B. Jimi
  • XC800.X
Posted May 05, 2002 - 10:44 AM
I sqease varsol through it,and then rinse it repeatedly with Sunlight and warm water. :)
  • 9 replies
  • 22 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  35 replies
