450 fork spring install
4 replies to this topic
  • Cirus
Posted October 03, 2004 - 03:26 AM
Can I do it myself? I've already changed out the rear spring with no problem but have never opened up a fork before. :cry:
  • John407
Posted October 03, 2004 - 03:55 AM
Yes you can do it, follow the steps in the manual and you can't go wrong.
  • gonzo
Posted October 03, 2004 - 04:51 AM
Change the oil while your there. The whole thing will only take about an hour. Quick tip loosen the fork caps while the forks are on the bike.
  • Cirus
Posted October 03, 2004 - 06:19 AM
Can the forks stay on the bike? It looks like the only think I should have to remove would be the bars so I can get to the caps.
  • Ga426owner
Posted October 04, 2004 - 05:56 AM
Loosen the caps while the forks are on the bike - otherwise you will need a vise with nylon or protective barrier to put forks in. Remove the forks completely to empty and clean - typical for contaminants to be at the bottom of the forks - remove the compression valve at the bottom when cleaning - I suggest you get it done first by a knowledgeable suspension tuner - then you should be able to handle it... :cry:
