New guy question...13 tooth sprocket
8 replies to this topic
  • loufish
Posted April 13, 2002 - 08:58 PM
New guy...just picked up my 02' XR650r...
Has someone replaced their 14t for a 13t c/s sprocket? How much top end speed did you lose? Did you gain enough lower speed to make it worth it?
  • Moredesert
Posted April 13, 2002 - 09:16 PM
I've always seen people put a 15 on becaues of the power. It had to get traction as it is with a 14. I ran a 13 on my 600 for the hills and 15 for the desert. It will make about a 8-10 mph difference on top end but more power on the low if you can use it with out wheel spin. Get a big fat 140/80-18 for it.
  • copelandn
Posted April 14, 2002 - 01:57 AM
I just got my 02 XR650R about five weeks ago.After my 2nd or 3rd ride i bought a 13 tooth sprocket. But before installing it. I Installed the honda compitition manifold,needle,seat,jetting,and baffle.AKA uncorked it. I now seriously doubt I will ever install the 13 tooth sprocket. This thing has power unbelievable in any situation.
  • Dutch
Posted April 14, 2002 - 02:44 AM
The main reason I use to change gear ratios is where I'm riding - tight single line trails up here in Northern Michigan need a 13 tooth sprocket. With a 14 tooth first gear revs too high and second gear goes too fast. With a 13 tooth you just stay in second. The BRP has the power to pull a 15 no problem. Gear for the track you ride.
  • dan_Rekito
Posted April 14, 2002 - 03:22 AM
A 13 tooth sprocket will wear a chain quickly. Stay with a 14 up front and add two or three teeth to the rear for woods or climb situations.
  • loufish
Posted April 14, 2002 - 03:32 AM
I never rode the bike with all the CA jetting, manifold, exhaust...it all got changed the same day I brought it home from the dealer, including replacing the entire exhaust. The 13t would be for tight technical sections, but I was also worried about it being so small, how would the chain handle it. Thanks for all the good info, now I have a place to start.
  • Matt96xr6
Posted April 14, 2002 - 04:22 AM
I use a 13T in the front of a 600 for the tight woods that I ride in. If I use a 14, I cannot get the wheel speed slow enough to get traction on some really bad hills.
The 13 helps a lot as you are usually in 2nd gear most of the time riding. Also installing a 50 from the stock 48 out back on my 600 would help. Top speed is down about 15mph, but can still pull 80.
  • qadsan
Posted April 14, 2002 - 09:17 PM
Here's some numbers to give you an approximate idea of the maximum speeds you'll get in each gear with the following sprocket combos. Please note these numbers are based on a maximum engine speed of 8,000 RPM among many other factors.
Gearing 13/48 14/48 15/48
MPH 1st....33.....35.....38
MPH 2nd...47.....51.....55
MPH 3rd....60.....65.....70
MPH 4th....75.....81.....87
MPH 5th....90.....97.....104
Gearing 14/50 14/51 14/52
MPH 1st....34.....33.....32
MPH 2nd...49.....48.....47
MPH 3rd....62.....61.....60
MPH 4th....78.....76.....75
MPH 5th....93.....91.....89
[ April 14, 2002: Message edited by: qadsan ]
  • Keyser_Zoze
Posted April 16, 2002 - 03:58 PM
For tight trail riding some guys like the 13 tooth sprocket. Personally, I prefer the stock gearing. I have a brand new 13 tooth moose countershaft sprocket for $15.00 delivered priority mail if anyone is interested. My cell number is 928 848 0205 or email me at: jp70@cableone.net
Thanks
jay
Honda XR650L 2016
  • 0 reviews
  • Hot  35 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 17 replies
