Allen Bolt sizes for carb on 94 XR650L
4 replies to this topic
  • 1biglung
Posted September 28, 2004 - 01:16 PM
I am going to replace the bolts on my carb with allen bolts.
Could someone list the sizes. I would like to pick them up on my way home and not leave the carb apart all night.
Thanks, Chris
  • XR650L_Dave
Posted September 28, 2004 - 01:43 PM
Shoot, I used to know...
They're real cheap at home depot, I just grabbed an assortment.
Don't forget to do the standard mods (drill, shim, de-snorkel, etc...). Of course, that's probably why its apart...
Dave
  • 1biglung
Posted September 28, 2004 - 01:52 PM
Correct Dave, I am going to Drill and Shim.
Also looking for the shim dimensions. Would you happen to know off hand?
Thanks
  • XR650L_Dave
Posted September 29, 2004 - 09:06 AM
0.030 inches thick, quite small in outer diameter. It needs an inner diameter that'll let the needle through, and an outer diameter that'll let it go down into the little 'well' at the bottom of the slide that the needle fits into.
Dave
  • 1biglung
Posted September 30, 2004 - 10:40 AM
:cry:
#4 washer
4-4mm X 10mm
4-4mm X 16mm
did the trick thanks.
Chris :cry: :cry:
