carb pilot
1 reply to this topic
  • bork
Posted March 02, 2002 - 10:48 PM
When purchased bike used, carb was all outta wack ! So I rebuilt, much better but the pilot screw has most rpm at all the way in. should be 1.5 - 2 turns out. Needle looks ok. Anyone else ever have this problem?
Also I weigh about 300 lbs , is there a weak spot to look for on frame to frquently inspect?
THANKS bruce
  • terryhotshoe
Posted March 02, 2002 - 11:24 AM
carb pilot yes check and see what the pilot jet is!!you more than likely need to change it!As far as checking frame check foot peg bolts keep them tight!!Also check where they mount to the frame cracks have been known to form around the footpeg mounts!!terry
  • Hot  35 replies
  • 22 replies
  • Hot  186 replies
Washington
  • Hot  32 replies
  • 9 replies
