CC vs MM down on a 46mm YZ450
5 replies to this topic
  • motocrosschump
Posted September 26, 2004 - 06:58 AM
Right now my bike is revalved by Factory Connection and I feel the fork is riding in the mid stroke much of the time. Its at 135mm down, but I want to bring it to 120mm. At the same time I don't want to break the forks down to measure, is there an conversion between cc's of oil and the measurement from the top?
  • fershy
Posted September 26, 2004 - 07:21 AM
pi (r*r) h
3.141527 (23*23)15= volume in cc's
  • motocrosschump
Posted September 26, 2004 - 09:46 AM
well I am good at math, but that theory work if the tube was empty. so I was hoping someone already did that.
  • Smegol
Posted September 26, 2004 - 07:20 PM
I think its roughly 1mL of oil for every 1mm of oil level.You might want to test it out yourself first as i'm not 100% sure.
  • motocrosschump
Posted September 27, 2004 - 04:05 AM
Thanks Bro.
  • fershy
Posted September 27, 2004 - 06:06 PM
You might want to pull your compression spring, drop it in a graduated cylinder and measure its displacement per cm/spring and report back to us.
Need help by Goforaride
  • Hot  68 replies
  • Hot  36 replies
  • 9 replies
  • Hot  491 replies
