WR into a YZ ?
7 replies to this topic
  • Sylvain
Posted September 26, 2004 - 05:33 AM
I know it may be sinful, but considering that I do my riding mostly on mx track these days, I want to lighten up my WR a bit. So I'm considering YZ-ing my wr.
I'm sure it has been done in the past, and I have a pretty good idea on what to do to acheive my objective. Quick/easy YZ/WR transformation.
But I'd like to know what some of you did and to what extend you went to YZ your WR ?
:cry:
Thanks
  • vantolr
Posted September 26, 2004 - 05:41 AM
There are literally 100s, if not 1000s of post on doing this......WROOSTER on the WR250F forum just did some good writeups with a number of links to former posts.....SEARCH!
Also, start here: http://www.thumperfaq.com/
  • Sylvain
Posted September 26, 2004 - 06:12 AM
Thanks :cry:
  • Dual_Dog
Posted September 27, 2004 - 01:23 PM
But I'd like to know what some of you did and to what extend you went to YZ your WR ? :cry: Thanks
IMS YZ tank which necessitates a YZ-style seat (Moose Gripper) & YZ radiator shrouds, YZ rear fender, YZ timing, Acerbis front number plate, Dr. 'D' full exhaust system, external coolant reservoir gone, kickstand gone. Definitely puts the bike on the Anna-Nicole Smith weight-loss program and drops off 10 pounds easliy, if not more.
No problems with the fuel petcock being on the right side either with the YZ tank. Just need a new longer fuel line (and zip-ties) routed up and over the carb to the inlet.
After coming off an XR650L recently, this bike feels like a 250! Power to weight ratio is unmatched, except for another WR!
  • WRSTEVE
Posted September 29, 2004 - 11:36 AM
The most noticeable difference will be the tank/seat swap out, I also changed my sub-frame and rear wheel to 19" as well as did the YZ timing.
all in all you will be glad you made the change. :cry:
  • Sylvain
Posted October 01, 2004 - 05:41 AM
I plan to do the YZ timing next time I check the valves. I understand well the reason to go with the 19 inch rear wheel. I have already the YZ seat and tank set. As a matter of fact I have an Acerbis 3.4 gal tank and the oem yz tank.
But why a YZ subframe ?
Thanks
  • WRSTEVE
Posted October 05, 2004 - 12:47 PM
Thanks
The YZ Sub is made out of aluminum, which shaves off some weight. :cry:
  • chipwich
Posted October 05, 2004 - 02:25 PM
the wr subframe is made out of aluminum
Edit: Oops. i see he is riding a 426. my bad. the 450s are aluminum.
