Broken bolt trouble help
4 replies to this topic
  • rush66
Posted September 25, 2004 - 04:19 PM
I accidently snapped off the right side tank mount bolt :cry: flush with the frame and was drilling it out to easy-out it and the drill bit caught somthing snapped and of in the hole :cry: the end of the bit is recessed a little bit I don't know what to do to get it out ? Are the mounts just a tube through the frame ? could I just cut the spot welds and remove the whole tube and weld a new one in and tap it ? any helpful advise is appreciated
  • yz426onNOS
Posted September 25, 2004 - 04:21 PM
Wow, thats a tuff one!!!! I'd say break out the torch.
  • Fastest1
Posted September 26, 2004 - 06:46 AM
Dont forget the oil tank is in the frame :cry:. You could drill it out and retap to a larger size much easier. You could try freezing it and chipping it out. The metal they make ez outs with is pretty brittle so it should fracture easily.
  • Davidyz450
Posted September 26, 2004 - 07:02 AM
Snap On, Mac, and Matco carry mini die grinder bits. They will tear through that bolt like butter. Then just retap hole or heli coil it. :cry:
  • dodge03
Posted October 05, 2004 - 04:30 PM
TRY HITTING THE FRAME AROUND THE BOLT WITH A PUNCH OR SOCKET EXTENSION EVEN AN AIR HAMMER IF YOU HAVE ONE. THIS SHOULD LOOSEN THE DRILL BIT THEN A MAGNET SHOULD GET IT OUT IF THIS DOESN'T WORK DREMEL MAKES VERY SMALL GRINDING BITS IT MAY TAKE A WHILE BUT SHOULD DO THE TRICK.
