Yoshimura digital temp gauge
2 replies to this topic
  • digitaldan
Posted 25 September 2004 - 08:28 AM
Has anyone used one of these gauges before. I saw one on a DRZ, not sure if it's just a temp gauge as it had lights for shifting and other functions as well. It also has two temp displays, one that goes to the bottom of the oil filter housing and the other to the right hand radiator. I have never seen any for sale anywhere.
  • Fullborewhore
Posted 25 September 2004 - 11:55 AM
That sounds cool ! I would like to see that with a Tach built in and a dam clock that you can use without being a math wizard! :cry:
  • NateTheGreat
Posted 25 September 2004 - 12:12 PM
I have researched this a bit. You can find some info on the Yosh temp gauges on the Japanese Yosh page which is also avaliable in english. I also found some Japan companies that distribute them. They also have a spedo called the GT Meter which has temp built in I believe and antitheft etc. No tach though. :cry:
There is a temp gauge that I believe has dual readouts and shift light also.
www.parts411.com also has lots of Yosh stuff check them for the temp gauges.
Check http://www.lockhartp...ages/search.asp also for temp gauges. There is a company called "daytona" (japanese also) LP distributes all of there items.
parts411 carries most LP products also. :cry:
