XR600 tripleclamps
4 replies to this topic
  • XR6's_rule
Posted February 23, 2002 - 08:09 PM
Has anyone out there used aftermarket triple-clamps on an XR600? I'm thinking of getting some for 94er. Any help MUCH appreciated.
  • MaXRSmart
Posted February 25, 2002 - 07:15 AM
I have the Applied triple and bottom clamp. I like them because I can change the risers to raise the bars up or forward or switch to taper bars. I chose Applied because it was a local (San Diego) company and they were very helpful. You also have your choice of different colors. Good Luck.
MaXRSmart :)
  • XR6's_rule
Posted February 26, 2002 - 12:20 AM
:) Thanks a lot for the reply MaXRsmart. I get a lot of flex from the ol XR's front end, most noticeable in ruts and choppy downhills, do the applied clamps help this much? And how much are they in American dollars? (I'll get a quote from someone local and see how much we get ripped off!)
Cheers.
  • MaXRSmart
Posted February 26, 2002 - 01:05 PM
The triple clamp helped with the fork flex, but it did not get rid of it. The SRC fork brace did a better job of getting rid of the flex.
The Applied clamp is about $135 US at Baja Designs. Here is a link if you want to check it out.
http://www.bajadesig...roduct_Code=493
Here is a link for more info on the SRC fork brace.
http://www.srcinc.net/forkbrace.html
MaXRSmart :)
  • XR6's_rule
Posted February 28, 2002 - 11:22 PM
:D Thanks a million for the reply MaXRsmart, great help. One of the only problems with the XR6 is with fork flex.
You may find this story interesting......
I actually have two XR600's, one RR (94') model & RJ (88') model. I recently did a top end rebuild on the RJ - aiming to find more power, but without losing it's reliability. So I ended up using a stock piston (which is lighter than the aftermarket ones anyway) and shaved 20 thou (.5mm) off the head looking to up the compression. Other than that I tidied up (but not altered) the inlet ports and fitted a staintune stainless exhaust (you may not have heard of these as they are aussie made). Anyway I ran the beast in and soon after went for quick squirt with a guy who'd just spent well over 10 grand (aussie dollars) on a new yammie WR426 with white bros exhaust. So of course he thought he was christmas until we had a few runs and the XR kept up and sometimes nuked it!! I'm stoked with the power increase given the resraint shown in the mods I did to the engine!!
So if you're rebuilding your engine take this on board. :)
Honda XR650L 2017
  • 0 reviews
  • Hot  35 replies
Honda XR650L 2016
  • 0 reviews
  • 3 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
