I have about 400 miles on this motor so I decided to give it the once over and when I was checking the valves 2 were tight just below limit and it looked like my cam lobes on the ex side wasn't quite at 108 deg instead of 10 o clock it was more like 9:30 ?? The arrows line up to the head so I'm confused and worried. They are yosh cams. 4 oilchanges the last 2 red line syn.
Valves??
Started by rockchucker22, Sep 23 2004 06:50 PM
8 replies to this topic
Posted 23 September 2004 - 06:50 PM
Posted 23 September 2004 - 07:02 PM
108 degrees isnt relative to looking at the lobes.its a lobe center line in realtion to crankshaft position.
the cam timing is fine.
what was the actual intake valve clearance?
Posted 23 September 2004 - 07:42 PM
On the left side intake was .005 and the other .003 was a tight fit and on ex the left side was .009 and the right was .006
Posted 24 September 2004 - 11:04 AM
Why so tight so fast?? Could they have put the motor together and not checked??
Posted 24 September 2004 - 11:11 AM
possibly.hard to say.reshim and check them often after.if they continue to move,you have a issue.
Posted 24 September 2004 - 12:15 PM
Valve job or only new valves? Would the heavy duty valve springs help?
Posted 24 September 2004 - 12:38 PM
Quote
Probably just new valves. If it turns out that you do have a valve wear or valve seat recession issue then heavy duty valve springs will only make it worse. You only need those if you are raising the rev limit
Posted 24 September 2004 - 01:43 PM
I have the yosh stage 1
11,000 cdi and cams with Ti valve retainers. I haven't been using the rev limiter until I do the first valve check (yea I know scared )....didn't want to float anything, So I was going to do the springs soon, and 440.
I just want to keep an eye on things I ride her rough
