----how much oil does the 03 YZ 450 hold ,in cc's--------
20 replies to this topic
  • brown77
Posted September 22, 2004 - 03:22 PM
How much oil does the 03 yz 450 hold when you change the oil and filter at the same time ( in cc's ) 1000???
Thanks alot
:cry:
  • YZ250F_Rider
Posted September 22, 2004 - 03:35 PM
1200?
  • brown77
Posted September 22, 2004 - 03:40 PM
IS that a guess ????
or is that what it is
  • del_scorcho
Posted September 22, 2004 - 03:45 PM
1100 cc's with replacing the oil filter.
  • mmbasa
Posted September 22, 2004 - 03:46 PM
What he said
  • brown77
Posted September 22, 2004 - 03:47 PM
Thanks alot guys
  • YZ250F_Rider
Posted September 22, 2004 - 04:22 PM
thats what it is. you asked how much can it hold. The book says 1200 cc's. The question mark was because I didnt have the book in front of me at the time. Call it an educated guess, or a lucky one. Depends on how you wanna look at it. :cry:
It also says
1000 cc's if no filter change, 1100 cc's with filter change.
Posted September 22, 2004 - 04:57 PM
It also says
The descrepancy is because there is a certain amount of oil that never leaves the engine except during a complete tear down. Dump a quart in and read the stick to go from there.
And now, my rant. With any '03 or later YZF, after you change the oil, you will be starting the engine with a DRY OIL TANK. Oil will have to be pumped back to the tank from the crankcase in enough quantity to supply the feed pump before anything gets oiled. For this reason, it is EXTREMELY important to do these 3 things:
1) run the engine for a couple of minutes to put a fresh oil supply in the top end and elsewhere. (the warm oil drains better, too)
2) start the engine as soon after you're finished with the oil change as possible, so the oil can be returned to the tank while the engine is still wet from step 1
3) KEEP THE REVS DOWN! Wait at least 30 seconds before twisting the crap out of the throttle so at least it will have oil pressure, even if it isn't warmed up.
There. I feel better. :cry:
  • Doug_Caldwell
Posted September 23, 2004 - 07:21 AM
I think that I saw someone put about 5000cc's (5 liters)in a 426. I thought that was funny, because they just kept pouring in the oil. I tried to tell them, but as always, they wouldn't listen.
I thought that it would not be possible to put as much oili in the 450, but I have seen almost 3000cc's (3 Liters) put in one of those too. The guy kept saying "What is wrong with this? I keep putting oili in and there isn't any on the stick."
:cry:
1100cc with filter, 1000cc without filter. :cry:
  • brown77
Posted September 23, 2004 - 07:47 AM
Thanks everyone :cry:
  • SureBlue
Posted September 23, 2004 - 09:07 AM
:cry:
OMG, this must be a joke, right? Usually reading the manual will not hurt. Or don't u guys get manuals with new bikes there? Or does the manual stay with the first owner as a memory of the bike? Unbelievable!! :cry: :cry:
  • Doug_Caldwell
Posted September 23, 2004 - 10:03 AM
I think that the problem is no one wants to read anymore. Everyone thinks that they know everything.
I may not know the correct way to check the oil on a Honda, but I would read the manual first to find out the correct way to do it.
  • SureBlue
Posted September 23, 2004 - 10:17 AM
you said it, Bishop Caldwell! :cry:
  • bigc
Posted September 23, 2004 - 05:40 PM
when i bought my 450 from the dealer he put like 2 quarts in,to bad it was already filled to begin with!
  • 6_ton_suzuki
Posted September 23, 2004 - 06:13 PM
i need to know how much 01 426 holds. :cry:
  • Matt96xr6
Posted September 23, 2004 - 07:00 PM
Straight from YDS:
03 450:
Capacity: Oil & Filter Change 1.1L (1.16 US qt)
Oil Change Only 1.0L (1.16 US qt)
  • brown77
Posted September 24, 2004 - 07:49 AM
ya but how mant cc's is that ?
  • Doug_Caldwell
Posted September 24, 2004 - 08:11 AM
1 liter = 1000cc
So you would need to put 1000cc (1 Liter) in the bike after you drained the oil and DID NOT change the filter.
OR you would need to put 1100cc (1.1 Liter) in the bike after you drained the oil and changed the filter.
Or if you split the cases you would need to put 1200cc (1.2 Liter) in the bike after you reassembled it.
  • ovrrdrive
Posted September 24, 2004 - 08:22 AM
cc's stands for cubic centimeters.
ml's stands for milliliters
One cc = one ml They are equivalent.
One teaspoon = 5 cc = 5 ml
One Tablespoon (Tbl) = 15 cc = 15 ml
One Tablespoon = 3 teaspoons
One ounce = 30 cc = 30 ml = 2 Tablespoons = 6 teaspoons
8 ounces (The common size for a formula bottle) = 240 cc = 240 ml
I found that interesting...
  • YZ250F_Rider
Posted September 24, 2004 - 08:33 AM
I find your finding it interesting, disturbing. :cry:
  • Hot  38 replies
  • 5 replies
  • Hot  47 replies
  • Hot  50 replies
