94 XR650L Sprocket reccomendation
7 replies to this topic
  • 1biglung
Posted September 22, 2004 - 09:08 AM
I just picked up a 94 XR650L w/XR's only pipe, jetting etc...
I want to play with the sprocket gearing and I am looking for suggestions. Sould I go with 13 front and 45 rear or 14 front and 48 rear or something different? The result would be about the same on paper but I would like to draw upon your experience.
I am also looking to add a tach. any reccomendations?
Thanks
  • truck6driver
Posted September 22, 2004 - 12:40 PM
I run a 14-45 in dirt and stock 15-45 long distance street. As for the tach if you find a good one post it. I was looking for one also. All I have been able to find is a digital one. I have found some for 2 cylinders but not a single.
  • HeadTrauma
Posted September 23, 2004 - 08:49 PM
Theoretically the larger the sprockets the easier it is on your chain. I would lean toward 14/48 or even 14/45 as mentioned above. I have 13/48 on my 600 and sometimes I wish it had more top end. Accelerates like a motocrosser and idles along at a walking pace, though.
A non-digital tach you might look at is one Autometer makes for Jr Dragsters. Its meant to be used on a single cylinder Briggs & Stratton type engine, although its not very small and may be meant for breaker-type ignition.
  • 1biglung
Posted September 24, 2004 - 06:54 AM
Thanks guys will get a couple front sprockets and a 48 rear and play :cry:
Head Trauma Do you know of a good digital?
  • MotoChris521
Posted September 24, 2004 - 01:27 PM
I've had 3 XRL's .It depends on what conditons your riding in.I ran a 14/48 combo on my last bike,and this bike also,but lately i went to 15/48 and it seems to be the best compromise. :cry:
  • DesertWill
Posted September 24, 2004 - 01:47 PM
I think it depends on what you have in mind.
I went to a 5.10x18 rear tire which made the stock 15/45 gearing too tall, so I went to 14/45. It's great around town and in the mountains but it buzzes a bit too much at 65-70 mph. I'm going to try 15/47 next.
One tooth change on the front equals about 3.5 on the back. A 47 tooth rear sprocket would allow you to try smaller, in between ratios than a 48. A 48 is almost like changing the front another tooth.
Will a 48 rear work w/ the stock chain guide?
  • MotoChris521
Posted September 25, 2004 - 06:53 AM
Yes !
  • XR650L_CDN
Posted September 26, 2004 - 09:03 AM
Just put a 14T on the front. Very happy with it. Would not be good for extended highway travel - but great overall on dirt and for shorter hauls (1 Hr or less) on highway. You start buzzin a bit after 65 MPH.
