Engine bogging...
2 replies to this topic
  • volk
Posted September 22, 2004 - 08:24 AM
I have a 97 XR600 that runs great, except when you try to quickly accelerate from an idle. If you are at idle and crank open the throttle, it will try to bog to a complete stall. If the RPM's are up a little, the engine runs spectacular and throttle response is crisp.
Is this a main jet problem? Am I running too rich? Will tweaking the air screw help fix this problem?
  • TimBrp
Posted September 22, 2004 - 08:35 AM
Tweaking the air screw may help. However, xr's are notorious for this misfortune. Every xr I have ever slung a leg over does this. Only thing to do is get the carb tuned perfect, and learn to deal with it. Or, go get a pumper carb.
  • truck6driver
Posted September 22, 2004 - 12:45 PM
Does the 600 have the same carb as the 650L or does that year still have the dual carbs? What mods have you done to the carb you have. I followed the advise of a friend about drilling the slide and shimming the needle, on my 94 650L, and got rid of my off idle throttle bog completely.
Ray
  • 9 replies
  • Hot  186 replies
  • Hot  29 replies
  • Hot  35 replies
Honda XR650L 2016
  • 0 reviews
