Smokin bike??????
2 replies to this topic
  • skeeder
Posted February 11, 2002 - 01:26 AM
Hello I have an XR650L and smokes at startup....alot.... and is burning one qt. of oil for one tank of gas. I was wondering if its the rings or the valves seal?????? or maybe a hole in the piston??? any ideals ... thanks
  • Dutch
Posted February 11, 2002 - 03:20 AM
When a motor smokes at start up that usually points to valve seals. Doing a leak down test where you can listen to the intake and exhaust ports,(crankcase also), will answer your question.
  • RedThunder
Posted February 11, 2002 - 10:30 PM
If you're burning that much oil, the top end is shot.
