450 cam in 400 - is this alignment correct (pics)?
7 replies to this topic
  • SXP
Posted September 21, 2004 - 09:55 PM
I'm in the process of installing a YZ450 cam (OEM) in my 99 WR400. Have I aligned the cams correctly? Thanks.
  • Chipstien
Posted September 21, 2004 - 10:34 PM
14 pins between dots.... looks good from here. :cry:
  • BrandonW
Posted September 22, 2004 - 07:23 AM
Yep, looks good.
I just pulled my '03 YZ cam out of my WR400, and put it in my new WR426.
That looks exactly like it should, and the bike rips and starts easy.
  • SXP
Posted September 22, 2004 - 07:51 AM
Brandon - Was your cam tight when you first put it in? Any binding?
  • BrandonW
Posted September 23, 2004 - 08:02 AM
The first time I put it in, there was "a little bit" of tightness.
I moved it back and forth (the amount of slack that was in the cam chain before I put the tensioner on) and it worked free.
Then I changed out my shims to adjust the valves in right, re-torqued the cam holder, and it was pretty smooth.
I did that a couple of weeks ago, maybe have 200 miles on it since, running like top, and starting like a dream.
  • russmitchell
Posted October 13, 2004 - 07:24 AM
Does the bike pull harder with the yz450 cam in it?
  • BrandonW
Posted October 13, 2004 - 10:18 AM
I am not convinced that the bike "pulls" any harder, but I swear that the top end never ends.
With the stocker WR cam, I could bounce off the rev limiter frequently.
But, with the YZ450f cam, I feel that it keeps strong RPM's for a long time, and never really bounces off the rev limiter like it used to.
It is well worth the time and effort for the starting benefits alone.
  • SXP
Posted October 13, 2004 - 11:53 AM
OK, I've got 2 rides in with the YZ450 cam and here are my impressions: the hit from the old YZ timed exhaust cam is gone - I was initially shocked and thought the bike had actually lost power. The power now just comes on linearly (some-what) and continues to build smoothly (as Brandon describes it above). Better for the kind of rocky, technical riding I enjoy. So, if you enjoy that hit, this mod is not for you. Starting is now ridiculously easy and if you stall a quick pull of the clutch and she lights up again. I some times wonder if the power delivery is not unlike the stock WR cam timing (less the decomp feature).
