Joe Racer VS Baja Designs The winner is
28 replies to this topic
  • qadsan
Posted September 27, 2004 - 08:55 PM
I dont feel it clicking at all and i do feel it going into the slot that feels right has anyone else ran into this prob ?
Make sure you're holding the throttle wide open, then gently push down on the tool and turn it until you feel it slide onto the slot. Once it's in there, you should feel it click, but the throttle has to be held wide open.
  • 3920
Posted September 28, 2004 - 06:08 AM
Yes i did hold it open all the way when pushing the adjusting tool all the way down and turned clockwise 1/2 turn. Still didnt feel any clicking bike ran better after warming up and riding a few miles when letting off idle was much higher and would idle down in about 10 to 20 seconds checked all cables all looked good so whats up with that ? did get rid of backfire tho thank god. should i turn back 1/4 turn for final adjustment on idle ?
  • qadsan
Posted September 28, 2004 - 06:40 AM
Something's not right. The bike should idle down much quicker than 10 to 20 seconds. Make sure you don't have an air leak between the carb & intake. You did cut out and or replace the stock intake manifold for the non EPA version, yes? Make sure those clamps are tight. I have mine setup so there's just a hint of popping on deceleration at times.
  • 3920
Posted September 28, 2004 - 07:13 AM
Yes i did uncork everything and did the blockoff kit as well I have checked and tightned the clamps front and back of manifold and collector bolts seems like a vaccum leak but where i dont know checked all caps on blockoff everything looks fine to me any ideas ? P.S. yes i did replace the manifold with factory hrc manifold
  • qadsan
Posted September 28, 2004 - 07:28 AM
Did you trip the alignment tab off the new rubber intake so it fits perfectly flush against the carb? That alignment tab is there for the stock carb, but gets in the way for the Edelbrock as I recall. Maybe that alignment tab doesn't interfere with the newer Edelbrocks, but it used to with the older ones and fitment wasn't perfect until that tab was trimmed off. That might be something to check.
  • 3920
Posted September 28, 2004 - 07:31 AM
Okay Im on it ! all i recall the carb went on smooth as silk but it's comin off again tonight ........thanks :cry:
  • Ibis
Posted September 28, 2004 - 08:07 AM
qadsan, did you set up your z Start Perch Adjuster with the light spring?
  • qadsan
Posted September 28, 2004 - 08:44 AM
  • Old_Man_Time
Posted September 28, 2004 - 09:18 AM
I use the lighter spring also but I did try the stiffer spring at first and did not like the engagement. For trail use the lighter spring is the way to go.
