increased spring rate/damping
5 replies to this topic
  • minioutlaw
Posted September 21, 2004 - 05:52 PM
I bought a pair of '89 CR250 forks that I'm going to experiment with on my '97 XR600. I got them cheap, don't know if I'll like them, and don't want to put a lot of money into them. I think I'll need heavier springs in them (stock is .38kg/mm and I was thinking .44kg/mm) which aren't too expensive and I can install myself, but I'm not sure I want to pay for re-valving. Would I be wasting my money by changing springs and not valves as well? Thanks for the input,
  • Roll_it_on
Posted September 21, 2004 - 06:51 PM
I think I would make the swap out and then see if you like the setup and think it is a positive change. Once you decide it is a good addition then I would spend the cash to get the right springs and valves to match your weight and riding style. Once you get the switch made post some pics :cry:
  • minioutlaw
Posted September 23, 2004 - 11:45 AM
Your idea does make the most sense. I was concerned that I wouldn't be able to tell whether or not I liked the setup if the springs were far too soft, but I guess that's better than spending $100 to find out the same thing. Thanks.
  • xr650Lroostnya
Posted September 23, 2004 - 02:56 PM
Why not just put heavier springs in your stock forks? :cry:
  • don87xr600
Posted September 23, 2004 - 05:02 PM
"cause upside down forks look cool?
  • minioutlaw
Posted September 26, 2004 - 08:16 PM
'Cause there's no better way to learn about stuff than to take it apart, swap it out, screw it up, and fix it again.
  • 3 replies
  • 9 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
Honda XR650L 2017
  • 0 reviews
  • 17 replies
