The Dangers of Synthetic Motor Oil *DELETED*
8 replies to this topic
  • Dutch
Posted September 20, 2004 - 07:12 PM
Post deleted by Dutch
  • truck6driver
Posted September 20, 2004 - 07:36 PM
Hey dutch,
Tell us how you really feel. :cry: :cry:
Ray
  • smashinz2002
Posted September 20, 2004 - 08:44 PM
Yep, and that is why I have always used nothing but
Honda GN-4 20w-50w 4-STROKE MOTORCYCLE OIL!! Funny thing too, this is what Honda recommends in the manual. I have no idea why? Maybe because they know what they are talking about since Honda actually designed and built the engine? And they have over 35 years of engineering experience with their engines? Yeah, I bet that's it.
LL.
'00 XR650R/uncorked/jetted/street legal
  • truck6driver
Posted September 20, 2004 - 08:52 PM
Honda does offer a full synthetic motor oil too.
  • smashinz2002
Posted September 20, 2004 - 08:59 PM
oh yeah thats right . . oops LOL
  • HondaXR650R
Posted September 20, 2004 - 11:06 PM
Thanks for the heads up. You probably saved me a real headache and about $10 a quart. :cry:
Note: I drive a Jeep Wrangler, and synthetic oil makes that machine run :cry: WORLDS BETTER :cry: than ordinary lube. I use :thumbsup:AMSOIL :cry: full synthetic 15w-40 "Diesel & Marine" oil and it works WONDERS on my Jeep motor. I will not, however, be using synthetic oil in my BRP. I appreciate the heads-up. :lol:
Nice writing, by the way. :cry:
  • Kritter
Posted September 21, 2004 - 07:48 AM
Works great in all my motorcyles. Works great in my truck too.
I will continue to buy it...I know the advantages!
  • 600ish
Posted September 21, 2004 - 06:20 PM
I have been using Mobil One MX4T 10w40 in my '94 XR600 for quite a while and this is a full synthetic motorcycle oil and I've been happy with it. What was Dutchs' deleted post saying about full synthetics?
  • BWB63
Posted September 21, 2004 - 06:50 PM
Of corse you all know there are two different types. Friction modified and non-friction modified. We can not use friction modified oil in our bikes! It will make the clutch slip. Hundereds use Mobil 1 red cap (NON-Friction modified) oil with no ill effects. You can not use an oil that is energy concerving.
Here is some of the dangers of synthetic oil... :cry: ;o)
Beware of synthetic oil, it can do terrible things to you and your
beloved motorcycle. It will not only leak out of your engine faster
than you can put it in, but it will also cause your oil filter to
clog and implode, dumping debris and dirt into your lubrication
system. It also will make every part of your bike permanently
slippery because of its linear molecular chain dispersion action.
Then it will leak onto your kickstand causing it to retract
automatically, dropping your bike on the ground! But that's not all...
Synthetic oil will round off your gears and spin your bearings. It
will also splatter onto your seat causing your girlfriend to fall off
in the apex of a turn and she'll never ride with you again. Synthetic
oil coats your sight window and your timing window with a whitish
pro-emulsification additive that is both non-removable and highly
corrosive. Synthetic oil will completely leak onto the ground overnight
and your dog will drink it and die.
Synthetic oil will wear out your tires and make your battery leak. It
will give you the desperate need to urinate after you put your full
leathers on and then jam your zippers shut. It will contaminate your
gasoline causing your bike to stall on railroad tracks and accelerate
uncontrollably near police cars. It will make it rain during rallies
and on weekends. It will lubricate your timing belts causing them to
jump teeth and break your valves to bits. Synthetic oil chemically
weakens desmodromic valves and causes the clearances to change every
six miles. Then it melts the black soles of your riding boots right
before you walk across your new carpeting.
While riding past groups of attractive women it will cause both of
your handlebar grips to slip off at the same time so you smash your
windscreen with the bridge of your nose. It also causes your swingarm
to crack, your studs to break, and your rotors to warp, and then it
voids your warranty by changing your odometer reading to 55,555. It
also dries out your wetclutch and wets your dryclutch. It makes your
clutch slave cylinder seal fail in the heaviest traffic on the hottest
day of the year while putting an angry wasp in your helmet for good
measure.
Synthetic oil hides your 13mm socket and puts superglue on your
earplugs. Synthetic oil will scratch your faceshield and make your
gloves shrink two sizes night before trackday. Synthetic oil stole
your neutral and sold it to the Chinese for $1.25. Synthetic oil
will make you grow a tail. Synthetic oil will write long crazy
e-mails to your Internet friends and then sign your name at the
bottom!
:cry:
