Hot Engine Stalls
5 replies to this topic
  • XR_Dude
Posted September 20, 2004 - 07:06 AM
Hi guy's,
I ride a '97 XR 600R. The Engine will stall with no warning at low RPM when the engine is hot. Note: the engine was recently bored out to 660 cc's and a performance cam and a Wiesco piston (normal compression) was installed. I installed the larger main jet that came with the kit. Any ideas what can be causing this?
XR Dude
  • qadsan
Posted September 20, 2004 - 07:54 AM
Here's some easy things to check out.
* try turning up the idle speed a little bit more
* make sure your fuel tank is vented and that the vent is working
* make sure your carb vent hoses are not clogged
  • XR650L_Dave
Posted September 21, 2004 - 08:52 AM
My XR650L would do this when the pilot jet was just a little too small.
-Dave
  • CrackiN
Posted September 22, 2004 - 03:45 AM
I don't know much but my XL600R did that and it was the stator....Have someone check the ohms output....
  • TimBrp
Posted September 22, 2004 - 08:44 AM
I would also check the engine temp while it's running. Those big bore kits can run quite hot. My buddies did and it had the same issue.
  • XR_Dude
Posted September 25, 2004 - 05:32 PM
TimBrp,
What did your buddies do to fix the problem?
  • Hot  29 replies
  • 4 replies
  • Hot  186 replies
  • 17 replies
