Mystery spark?
3 replies to this topic
  • ROTROD
Posted September 19, 2004 - 04:22 PM
Hey gang.Got a problem.My 650l will run for a couple minutes and then die,from a loss of spark.If I toggle the run/off switch and hit the starter it will fire up and run again.It will do this several times,and then it won't run for a while.I have gone through all the plugs and connections,and tried to make sure there are no bare wires or grounds.I am wondering about the coil or the CDI.The bike shops here have no idea and figure I should replace both.Sounds fine except if that don't fix it,no returns.Anyone have any ideas on this?I don't know what to do. :cry: :cry:
  • Butta
Posted September 19, 2004 - 04:24 PM
If cycling the on/off switch really works, and is not just your routine after it dies, then wrap the handlebar under the switch with electrical tape....it may be grounding out. Just a thought....I always go for the easy fixes first.
  • XR650L_Dave
Posted September 21, 2004 - 09:04 AM
Could be the resistor in the plug cap is going bad- a cheap fix to try.
-Dave
  • XR6's_rule
Posted September 23, 2004 - 01:41 AM
90% of spark problems stem from a bad stator, test it first using a multimeter, failing that it would be your coil.
Good luck!
  • 7 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 0 replies
Washington
  • Hot  32 replies
  • 17 replies
