Regina Z-ring chain & 80w90 gear lube... YUCK
8 replies to this topic
  • xr600r
Posted September 18, 2004 - 07:25 PM
I just put on Iron Man sprockets, and the Regina z- ring chain. Regina says to use 80w90 gear lube on the chain.
i was hesitant to do this, but did anyway. as i suspected, the chain looks like crap from all the sand sticking to the gear lube. i know the chain lube subject has been worked to death, but does anybody have any opinions on using gear lube as a chain lube ? i know i'm not to impressed with it.
  • 5valve
Posted September 19, 2004 - 12:46 AM
you made a crappy business buying regina anyway, any other would be better quality :cry:
  • xr600r
Posted September 19, 2004 - 07:27 AM
Thank you for your input, Mr. 5Valve :cry:
anyone else care to contribute ? :cry:
  • blireef
Posted September 19, 2004 - 09:01 AM
just say no to gear oil! :cry: :cry:
Regina's are fine.
  • 5valve
Posted September 19, 2004 - 10:14 AM
I ment what I said, had already 3 broken reginas, that werent even close to stretched, while I was waiting for new one, I put on some stretched to the max DID, and it was going bulletproof
the most crappy part on regina is connector link, as the plate is not stiff enough
thats why use cheap X-ring chain (industrial 520), with very high stretch resistance and lube it with engine oil, grease or whatever lube i find, but make sure the riding conditions match the lube - anyway deep mud and water wet-clean any lube in a matter of seconds
remember that much italian mid to high-tech stuph is crap!!
  • blireef
Posted September 19, 2004 - 02:47 PM
Wow, Ok I believe you but You must be getting some serious HP out of your scooter, I haven't broken a chain for so long I don't even remember when it was. ( Was I stupid enough to just say that??? I better bring an extra on the next ride) :cry: :cry:
  • 5valve
Posted September 19, 2004 - 11:28 PM
sorry I wasnt replying to you, my mistake :cry:
the first gone bad on a TTR600, low quality o rings
no chain will break if you change it every 1500 miles (of real workout), but quality shows in prolongued use
to think Im not the only one to dislike the reginas, there is quite a substantial number of people avoiding them
road reginas are supposed to be fine, as they are not so dirt enforced
just for you, no need to carry the whole chain, but an extra connector link in a pocket is a must in serious trailing
  • Eric_F
Posted September 19, 2004 - 11:51 PM
My uncle had a chain break on him in the late 80s, and it came up and put a huge gash in his back! Ouch! Can this happen with the modern cycles as well?
  • xr600r
Posted September 20, 2004 - 01:09 AM
If a modern chain decides to slap you silly like that , i would seriously recommend anger management classes for the chain. BHAHAHAHAHAHAHAH. god i'm bored. :cry:
