rear tail light
10 replies to this topic
  • JUSTNEIL
Posted September 16, 2004 - 10:20 AM
why is there 3 wires going to the taillight.
only one filiment lights up.
is there a switch to get so i can make it a brake light as well. and where do i hook it up:like how do i plug it in :devil::thumbsup:
  • r_dawg1021
Posted September 16, 2004 - 12:09 PM
You can buy the switch for front and rear brakes and this allows the brake light to work. Take out the stock banjo bolt and throw the swtich in, bleed the brakes and you're done. Took me about 10 minutes to get my brake light up and running. My stuff came with my Baja Kit but you can get them pretty much anywhere. I'm sure TT store has some that'll work for ya' It's slipping my mind what the exact name of it is though, someone will say it thought I'm sure :thumbsup:
  • redrider77
Posted September 16, 2004 - 03:03 PM
What did you tap into to power the brake filament?
  • basicblues
Posted September 16, 2004 - 05:29 PM
I recently installed a brake light switch. I ran one wire directly to the battery. The other wire was spliced into the yellow wire that goes to the rear bulb. The brake light works when pedal is pressed regardless if engine is running or not. Very simple installation. I have russell speed bleeders so bleeding the brakes was a snap. Good Luck
  • RichBaker
Posted September 16, 2004 - 05:34 PM
A fuse in the wire between battery and switch is a very good idea. Otherwise, that's how I wired my rear brake...didn't worry about the front switch. :thumbsup:
  • Gadsen
Posted September 16, 2004 - 05:47 PM
Use the same power source that runs the running lamp, just "T" off of it, run one wire from the hydraulic brake swith to the "T" and the other end of the switch to the empty wire in the tail lamp. I did it this way so my lights work when they are on, not when they are off. I also replace the tail light bulb with an LED bulb because the stop lamp would pull my headlamp down. Now I dont know if tis an issue on the new 450, but the headlight and tail lights are AC and run on their own lighting coil.
  • blireef
Posted September 16, 2004 - 06:41 PM
I vote too but let's not get started on politics. :thumbsup: :devil:
  • OrionEngineer
Posted September 16, 2004 - 08:04 PM
Is there an LED light you can buy or do people just make them? I was about to make one, but I figured I should ask first.
  • Gadsen
Posted September 16, 2004 - 08:57 PM
No, you can buy them. Its basically an 1157. Use Ebay, best prices, get the clear LED's, though, the red ones will work, the clear ones are brighter. I have a bunch. On Ebay, type in the search "LED tail lamaps" or LED bulbs.
  • Gadsen
Posted September 16, 2004 - 09:00 PM
I vote too but let's not get started on politics. :devil: :thumbsup:
I cant find anything in any of these post regarding voting. So it appears the only one starting it would be you. Now if you reffering to my avatar, ignore it, get over it. Stick to the post! :awww:
  • Birdie426
Posted September 17, 2004 - 10:26 PM
You can also pick 'em up at the local AutoZone or Pep Boys...I think I paid $11.00 for a pair at AutoZone.
