Tall Bars or Not
19 replies to this topic
  • Thumper38
Posted September 16, 2004 - 04:49 AM
I was just wondering what bars you tall riders are running? I am 6'3". I am thinking about some really tall bars so that I am not so hunched over while standing. Give me some info guys, is there anyone who tried this? :thumbsup: :devil:
  • John_Lorenz
Posted September 16, 2004 - 06:15 AM
I am 6'2" in the morning
I was using the Pro-Taper CR-Low bends,and just went to the High Bends, it raised them enough for me to be very comfortable now. I know some are using the Jimmy buttons, I did not like the sweep on them so I opted for the High.
One other thing you can do as a tall rider is the Peg mod if you have not done this. It puts the peg about 3/4 down and 3/4 in back For me it made my foot fit better for my style and did not feel so cramped
  • SureBlue
Posted September 16, 2004 - 06:47 AM
I am 185 cm and prefer high and straight bars to keep the elbows up. I have Magura sx fatbar with clamps mounted on stock upperclamp, they rise the bar a bit. I think Protaper Doug Henry -bend is straight and high, someone had them here, sjwr450? Anyone with experiences, I was thinking of getting them.
  • Aaron
Posted September 16, 2004 - 06:57 AM
I have buttons on both of my bikes and am happy with them. the pastrana bend looks interesting too. i just dont want any pastrana stuff on my bike cause ill be jinxed.
  • cowboyona426
Posted September 16, 2004 - 09:28 AM
Doug Henry bend Pro Tapers with universal adapters and an 02 top triple on my bike. Oh yeah, 6'2".
  • SureBlue
Posted September 16, 2004 - 10:01 AM
Cowboy, you would not have a rider's wiev photo of your Doug Henry -bar to see the bend, would you? Thanks in advance. :thumbsup:
  • mopos
Posted September 16, 2004 - 11:03 AM
What about those bar clamps that raise the hight of where the bars clamp? Are they weak? Instead of replacing the upper triple.
Also, do they make them so you can fit fatter bars?
Has anyone found bars that fit the stock upper triple and raise the height enough?? A lean 6 foot 6 inches, without the helmet!
Thanks!
  • ncmountainman
Posted September 16, 2004 - 01:26 PM
thumper racing makes bar extenders up and forward 1" or one that does 1.5" they make them for stock or large bars. i have used the 1+1 and they worked great i'm 6'4" the quality was excellent but they were not cheap $80 :thumbsup:
  • Gizabious
Posted September 16, 2004 - 03:09 PM
6'3 tag sx bend bars with tag bolt on clamps which raise the bars another 15mm. Never once had a problem with the clamps, and a much cheaper alternative to a new top triple clamp.
  • Satch0922
Posted September 16, 2004 - 05:39 PM
6'1" and I love the Windham bend ProTapers...using an Applied top clamp...no risers.
  • Chipstien
Posted September 16, 2004 - 05:41 PM
Thanks!
Here you go! :thumbsup:
http://www.protaper....armountkit.html
  • cowboyona426
Posted September 17, 2004 - 10:10 AM
Cowboy, you would not have a rider's wiev photo of your Doug Henry -bar to see the bend, would you? Thanks in advance. :cry:
I have one at ATM, but you have to be a member there to view it. I'll try and snap one tonight and post it :cry:
  • thelimey1
Posted September 17, 2004 - 09:37 PM
im 6'3" i bought the pro taper triple clamp, and used the 55mm high risers that you can order seperately. 55mm makes a big diff. i also use tall bars in conjunction. real comfy.
  • cowboyona426
Posted September 18, 2004 - 09:01 AM
Here's a link to a new album I created, hope this is what you were after.
Bar pics
  • Anssi
Posted September 18, 2004 - 11:56 PM
I run KTM bend Fatbars with the universal mounts on my -03. The KTM bend is very straight in addition to being reasonably tall, this helps if you also have wide shoulders (since your arms will come in "from the outside").
I'm 6'4".
  • SureBlue
Posted September 19, 2004 - 05:52 AM
Thank you Cowboy, buy you a beer! :cry:
  • Chipstien
Posted September 19, 2004 - 11:14 AM
Hey Cowboy, I see you are running the Rally Pro's. I was going to do the same setup as you untill I realized I would have to buy the oversized mounts for my Rally Pro's AND figure out how to remount my Trail-Tech computer. I have since put the Fat Bars on hold. :cry:
  • cowboyona426
Posted September 19, 2004 - 11:34 AM
IMO, don't buy the Rally Pro's. They look nice, but they bend way to easy. Plus, as you mentioned, the setup is EXPENSIVE!
Handguards- $65
Fat bar mounts- $30
Triple clamp mounts- $50 (usually $100 or so)
Total- ~$150-$200!!!
Cycra Pro Bend racer pack with triple clamp mount- $120!
Next time, I'll go with the Cycra setup. You NEED the triple clamp mounts on the Rally Pros unless you want them to bend after every crash. Plus, with the Cycra setup, you don't need to cut your clutch lever.
  • Chipstien
Posted September 19, 2004 - 12:04 PM
$85 for my Rally Pro's complete with everything needed. However I did not get the TC mount. I personally haven't had any problems but then I rarely opt to "kiss the ground" so I have never bent them. They are there strictly to keep trees from having that uncontrollable urge of planting themselves in the middle of the trail right after a corner. :cry:
  • cowboyona426
Posted September 19, 2004 - 01:37 PM
You realized you just jinxed yourself, don't you? :cry:
  • Hot  28 replies
  • Hot  30 replies
  • Hot  50 replies
  • 5 replies
