o-ring or not?
3 replies to this topic
  • *mike68*
Posted June 26, 2001 - 04:05 AM
Does everone run o-ring chains? Any advantages to running a non 0-ring chain? I prefer low maintenance items. Anyone from Bills can tell ya that.
01 426 "sewing machine"
Custom cracked headlight:
Custom bent and twisted header pipe:Custom repaired break lever:custom repaired clutch lever: Custom dented moose skid plate: Custom dented frame: Custom scuffed side number plates: Custom scuffed front and rear fenders: Custom stock jetting: Custom vortip: Custom stickers
  • Rich_in_Orlando
Posted June 26, 2001 - 05:08 AM
I think that for maintenance reasons, an o-ring chain is the only option. Otherwise, you'd be replacing chains and sprockets way more than you'd want to. The only advantage to a standard chain would be reduced rolling resistance, so you'd have a little more power at the rear wheel.
  • mcarp
Posted June 26, 2001 - 06:11 AM
Yeah, get the o-ring chain. Internal rust is what will kill the chain, o-rings prevent or at least minimize contamination. The extra power you'll lose is minimal.
The DID x-ring (VMX) is a great chain. A little expensive, but they last about 50% longer than a comparable Regina or RK and stretch very little. I've had the same chain for abour 600 miles, 2 adjustments required and one was after a long extremely muddy ride.
  • *mike68*
Posted June 26, 2001 - 07:05 AM
It looks like next year I will be running stainless o-ring chain and sprockets.
