wide ratio gearbox
wide ratio is better for trail riding and a wide range of speeds. You can crawl at 6 mph or go 90 mph with the WR 5 speed gearbox. It is fantastic! I love the first gear for technical nasty terrain and 5th is great for cruising down the fire roads. ? Did I mention that I love my WR450! :devil::awww:?
Yes I have topped it out several times. You need a 15 tooth front sprocket to get to 100mph or 16 tooth to get to 110 mph. I think the 16 tooth is the biggest that will fit. ? The 05's are green sticker in California. The 03's and 04's are not unless you imported them from Canada. :devil:
