chain hitting square aluminum uprights on bike?
3 replies to this topic
  • Chevy_Cowboy
Posted September 13, 2004 - 05:00 AM
Hey guys, earlier I was putting silicone under my chain slider and doing some other odds and ends to the bike and I noticed some scaring on the inside of one of the square aluminum subframe... the only thing that could have caused it is the chain. Is this normal? Is there anything I can do to prevent it? I didn't see anything on thumperfaq about this. :thumbsup:
The bike has less than 100 miles on it and I've been pretty easy on it so far.
  • Indy_WR450
Posted September 13, 2004 - 08:22 AM
That is normal. I have a pc of 1/8" thick UHMWPE plastic mounted on the inside with mounting tape. It protects the sub frame arm. You need to cover it about 4" length. :thumbsup:
  • pokey1
Posted September 13, 2004 - 09:34 AM
Mine's doing that, too. With only about 300 miles on it. I'm surprized that Yamaha didn't put something there to protect the subframe.
  • DirtyDude
Posted September 13, 2004 - 12:27 PM
Absolutely!! Mine has done this since new, and I was going to put a piece of plastic on the subframe too. The slack has always been in spec too. It seems to help if you keep the slack setting a little less than the max spec. Odd thing is I have a friend with an '03 WR450 and he has almost no wear on the subframe. We both set our slack the same too - we use an AA battery placed between the chain and the swingarm right where that allen connects the rear of the slider. Weird. A makeshift guard is definitely in order. :thumbsup:
