03 yz450f Spring rate????
4 replies to this topic
  • motolawson
Posted September 10, 2004 - 06:00 PM
I weigh 215. Is stock fork spring too soft??
  • SureBlue
Posted September 12, 2004 - 11:16 AM
Check the last section "Tuning" from your manual. All spring rates for differnt rider weights are there.
  • CrashDaddy
Posted September 13, 2004 - 04:48 AM
I weigh 215. I went with .48 fronts, world of difference. I also went with 5.8 rear, I think it's a little too stiff from the way I have to set the bike up. But I like it. I'll probably change to a 5.6.
  • RWCWOH
Posted September 14, 2004 - 04:01 PM
On MX-tech sping calculator a .479 fork sping rate was
recomended, but race tech only has .49 for '04. They were better than stock for my 225 lbs., but caused arm pump in the whoops. Last week I swapped out one stock spring ,.46,with the .49 and the difference was awsome!!! The bike turns so much better now and it is easier to go fast now. I also have 5.6 rear spring with 100mm rider sag.
  • MxHuggy
Posted September 14, 2004 - 08:33 PM
Yes i would think that you may have to spend some$$$$$$ here!!
My tuner said that I was on the bubble and I weigh 180 w/o gear. After the changes the bike did handle much better. Well worth the money!! :thumbsup:
  • Hot  38 replies
  • On January 15, 2017
  • Hot  50 replies
  • Hot  36 replies
