2001 YZ426 clatter somewhere around water pump
11 replies to this topic
  • mattl
Posted September 08, 2004 - 06:20 PM
I was wondering if there was a problem with the clutches on the 01 models. I have a pretty loud clatter and it sounds like it is coming from somewhere around the water pump. Is there any known problems that could cause this. I have read about the keyway on the 00 models. Any help would be great. Matt
  • 426F
Posted September 09, 2004 - 04:34 AM
Are you sure you don't have a '00?? I have been in that situation before. Check your VIN number if you are unsure.
  • mattl
Posted September 09, 2004 - 05:22 AM
I am not for sure how to tell from the vin number but it is
JYACJ01C41A022707
The noise that it is making doesn't seem to have an effect on its performance it still starts easy and runs perfect.
Thanks for any help
Matt
  • Matt96xr6
Posted September 09, 2004 - 07:04 AM
YOu can tell the year by the 10th digit. 1 is an 01 year bike.
My suggestion is to drain the coolant and remove the water pump cover to do an inspection on the bearings and impeller. IF you dont find anything there, keep going.
  • TheEnvelope
Posted September 09, 2004 - 12:48 PM
My 02 had some clatter. Now it's dead! Thought the problem was a broken spring on the back of the clutch basket. I'd take your clutch case off and the take the whole clutch off. Unfortunately it turned out to be my crank bearing. It shattered and destroyed my whole motor. Scored cyl, broken clutch case, busted oil pump, and a motor full of shards.
On a lighter note, it may just be your water pump bearing, but take that side case off and have a look, before it's too late like mine. :thumbsup: :devil: :awww:
  • mopos
Posted September 15, 2004 - 11:47 AM
So what is the outcome? I just bought a 01 426 and it has an ugly noise coming from the lower end. I am about to dig into it tonight. Any help would be great!
Thanks!
  • felony
Posted September 15, 2004 - 12:04 PM
my 01 426 has some chatter as well from time to time,i have 3 rides on a new oem crankshaft assembly and cylinder so i know its not that.it has done it for as long as i can remember,i inspected water pump assembly while i had it apart,all looks good as far as i can tell.could just be mechanical noise,its not obvious like YOU know something is wrong but when you work on your own bikes and buy your own parts youtend to get weary of any noise.. :thumbsup: if somebody has a reason for this hopefully they'll post and help us all out
  • mopos
Posted September 15, 2004 - 01:48 PM
Yeah, I think this is a pretty odd problem. Seems that it is either something to do with the lock key, but I read that is only on 2000's because 2001 is splinned<SP?>. Or there is something wrong with the water pump...
  • mopos
Posted September 15, 2004 - 05:02 PM
Uh, what if the 10th digit is a letter???
  • Hamish
Posted September 16, 2004 - 02:49 AM
my 01 makes a similar racket. Mine is the clutch basket onto the driven gear. All the springs are loose. You can rotate the basket about 1/8" without the gear moving.
Trying to decide if I should go aftermarket or OEM. Anyone know if you can get basket springs aftermarket? (sorry for hijacking the thread!)
  • 426F
Posted September 17, 2004 - 05:03 AM
the 10th digit is a letter. Y is for 2000. Z is 2001. X is 1999. Double check your VIN # mattl.
  • PMK
Posted September 18, 2004 - 07:53 AM
Agreed. I would be certain you have a 2001 motor in that bike and not a 2000. I have worked on 426's that the owners thought they had 01's but really they were 00's. It sure sounds like a loose gear / worn keystock issue.
As for the clutch basket and it's torque springs, I don't know of any one selling seperate springs. The real trick is to build the basket to not use a metal spring but rather a material that will be non damaging to the gearbox if bits fall out. I think the metal springs fragments have been responsible for a lot more trashed gearboxes than they get blamed for.
PK
  • 10 replies
  • Hot  36 replies
  • Hot  113 replies
