tricks for xr 600
1 reply to this topic
  • XR_600_Maniac
Posted August 21, 2001 - 12:48 PM
My bike is awsome stock but I want to perk it up alittle any ideas besides pipes and jets
  • Matt96xr6
Posted August 22, 2001 - 05:55 PM
Pretty standard honda stuff:
1. remove the aibox baffle. Remove the seat, then the part sticking into your airbox
2. get a uni-filter that has a new cage and ditch the stock cage and filter
3. take the header pipe off and at the head of the pipe, remove any welding slag left there
4. make sure you have the decompression and valves adjusted properly
5. rejet the carb with a 6 pilot, 165 main
6. from there it is exhaust. wether you put a tip in the stocker or go aftermarket
7. Tune the suspension! change the fluids for sure with new high quality fluids!
of course it should be without saying that a new plug and changing the motor oil and oil filter regularly is needed! Also greasing the steering head bearing and squirting the zerks for the rear suspension linkage
Here is a few more links to look at:
Fell Off Trailer by usafxr
  • Hot  43 replies
FCR40 Tuning Woes- XR600R by aTuWitty
  • Hot  37 replies
What was your path to Beta? by officialhopsof
Dirt Bike   Make / Model Specific   Beta
  • Hot  79 replies
1993 XR600R rebuild by ove
  • Hot  41 replies
Can anyone identify this xr600 piston? by ms_mtn24
  • 4 replies
