Long Signatures
15 replies to this topic
  • mcarp
Posted June 24, 2001 - 11:52 AM
Guys,
I'm finding that when doing searches for items like "scotts damper" that many items come up only due to the fact that scotts is listed in someone's signature. Rarely is the item in question actually discussed. Also, extra bandwidth is needed to process all this, not a big deal for me-cable modems are fast, but it's costing Bryan $$ and time for all you modem users to bring this up.
Can we refrain from posting a long signature? I saw a few guys have 5-10 line signatures with every last mod they have performed. I know we're proud of our bikes, but is this really necessary?
Does this bother any one else? Do we really care if a member has "Factory Effex seat and graphics kits" as posted on signatures? I'm guessing, "NO", we don't care.
  • Bill
Posted June 24, 2001 - 11:58 AM
Thanks for reminding me Mike :) I forgot I had a damper. I've just added to my signature :D :D :D
How many lines do I have now :D
Bill :D :D
PS I have gotten emails from members asking about the mods I show in my signature :D
99 WR400f, YZ timed, MX-Tech suspension, Scotts steering damper, White Bros E-Series (12 discs), tapered header and a/f. Kouba T-handle for the fuel screw. Works Connection billet throttle tube and frame guards. Cycra Pro-Bend, triple clamp mount handguards. Thumper Racing rad guards, Renthal Jimmy Button highs, YZ Tank and IMS seat, YZ number plate, odo removed, EKP, 48PJ, 175MJ at 500-1000' Thanks James Dean!
[This message has been edited by Bill (edited 06-24-2001).]
  • mcarp
Posted June 24, 2001 - 12:26 PM
:) Bill, you crack me up...but I think you DO understand what I'm talking about...try a search for something and see how annoying all the posts get.
Otherwise I'll make my sig about 9 lines long. If you can't beat 'em, join 'em!!!
  • *mike68*
Posted June 24, 2001 - 06:02 PM
Mike,
I fixed mine for you :)
01 426 "sewing machine"
Custom cracked headlight:
Custom bent and twisted header pipe:Custom repaired break lever:custom repaired clutch lever: Custom dented moose skid plate: Custom dented frame: Custom scuffed side number plates: Custom scuffed front and rear fenders: Custom stock jetting: Custom vortip: Custom stickers
  • mcarp
Posted June 24, 2001 - 08:01 PM
Now you're asking for it... :D :) :D
Mike, you forgot the custom rear brakeline air with gritty lever :D Oh, and the custom thrashed stock chain deserves mention :D
Guys, I had a blast in PA, hopefully we can get together soon. Wonder how far NH is from Ohio????
'00 WR400, YZ timed, YZ pipe w/ WB Ti Tapered Header, MX-Tech forks, Acerbis YZ plastic, Stock YZ tank, Scotts Damper, TAG T5 Cr Double High w/ stock reversed clamp risers, Maier Woods Pro handguards, Topeak Panoram, Hebo juice clutch, Fastline's Fr. and Rr, Gold Talon Hubs and sprocket, Gold Excel rims w/ Bulldog spokes, Michelin S12 Fr/D755 rr tires, Guts soft foam with One Industries graphics/grippy seat cover, Grey wire cut with switch,
Jetting EKN#4, 170MJ, 48PJ,#100 MAJ, Kouba Fuel Screw adjuster (Thanks to Bill :D ), WB airfilter,Acerbis Fr Disc Guard, Heated grips, Devol Radiator Guards, Moose skid plate, Fredette chain guide, 13/49 gearing, DID X-ring, odo/cable/coolant res removed, Water-wetter, and last but not least Mike68 "custom" hefe-weisen stickers :D
  • *mike68*
Posted June 24, 2001 - 11:34 PM
nice signature
  • Bryan
Posted June 25, 2001 - 04:52 AM
OH MAN! You guys have WAY too much free time!
Bryan...
  • Mr_Toyz
Posted June 25, 2001 - 06:51 AM
I'm guilty....
I got to redo mine when my old profile got deleted in Bryans last service interuption.
I guess I do see you point though, I saw it as an oppourtunity to see how much $ money I've spent on my baby. I actually like reading other peoples signatures though, I think it's help full to see what other people are having luck with...
But...OK...I'll...delete...sniffle...sniffle
JJ
99 WR - WR timing, EKN #3, 01 YZ exhaust, Clarke YZ tank, YZ rear fender, IMS YZ seat base, Factory Effex YZ seat foam, Factory Effex graphics and seat cover, Decal works pre-printed numbers, Scotts stabilizer, Scotts upper triple clamp, Pro Taper CR Hi's, Trail Tech Panoram computer, Terry Cable hot start, DSP Carbon Fiber upper fork guards, Fastline Steel braided front brake line, Motion Pro Terminator clutch cable, Renthal grips, Cycra Pro-bend hand guards, GYTR triple clamp mounts for hand guards, Moose skid plate, Flatland Racing radiator guards, Flatland Racing odometer spacer, GYTR front disk guard, GYTR plastic frame guards with 3M grip tape, Michelin S-12's, Renthal Groovelite sprokets, DID 520 X-ring chain, TM Designs chain slider, 5.6 Racetech rear shock spring
[This message has been edited by Mr Toyz (edited 06-25-2001).]
  • MOmilkman
Posted June 25, 2001 - 09:39 PM
OK, if everyone else is doing it then Im doing it too. :)
Darin in Missouri - 1999 WR400F
Enduro Heaven Heres my list!Enduro Enginering Hand Guards with MSR brush guards - Pro-Tapers CR-Hi Bend – Powder coated gloss black by Andrews powder coating – Works Connection clutch perch – Lever skins (black) – Applied racing top triple clamp (blue) – Thumper Racing bar risers +1.5 – Terrycable steel braided clutch cable – Motion-Pro throttle cables – ProGrip grips – MSR skidplateDunlop 755 front – Dunlop 739 rear – Hurricane Hannah retro graphics kit including YZ style front fender, YZ style rear fender, YZ style number plate, w/ One industries graphics kit – DSP carbon fiber disc guard – DSP carbon fiber fork guards – KYB carbon fiber stickers for upper fork tubes – WER steering dampner (rebuilt 100 times) – Factory Effects Backgrounds (clear) – Factory Effects 8” Digits (#24) – shock servicing by Tomlin racing – uncorked, took airbox lid off, cut throttle stop and ditched the boat anchor of a exhaust - Works Connection frame guards – Scotts performance Billet Shark Fin – Clarke YZ tank 3.3 gallon – YZ seat w/ One industries Hurricane Hannah retro style seat cover – Works connection rear brake caliper guard – Carbon fiber looking stickers for airbox from Factory Effects – Maxima Filter oil – Grease zerk on steering head – P3 Pacemaker computer for Enduros - UniFilter Air filter – Filterskins by PC racing – Spectro 10W40 synthetic oil in winter 20W50 in winter – stock yamaha oil filterFMF Powercore IV spark arrestor – ProCircuit Ti foot pegs – MSR lower chain roller - Thumper Racing wrap around radiator guards – Spectro coolant – Homemade brake snake – Rejetted from 168 stock to 180 on main – Heavy duty tubes (front MSR – rear Bridgestone) – changed oil every three rides – clean oil filter every 3 rides – took bike to the dunes and tore completely apart and got all sand out and put back together – thinking about getting more cool stuff for it –Fox fanny pack with lots of tools - Helmet Cam from www.helmetcamera.com - Bell helmet Choidi style – Answer Edge chest protector – Answer elbow pads – Alpinestar Tech 8 boots black – MSR gear as follows: 2 vented jerseys (this years model and last) , MSR system 6 pants (this years and last) – Fox Racing Dirtpaw gloves yellow – MSR system 6 gloves blue – No fear socks (black and white) – Moose knee pads (very comfy I might add) – Moose gear bag – Kevco-Stubbs kidney belt – Camelbackstabbers drink system – Scott Goggles clear – Roko quick strap – Smith roll offs – double payne lens- and I have a blue and grey lens too – MSR goggle bag – MSR raincoat – Underwear glove liners – Hanes briefs with skids – Breathe right nasal strip when racing – Gatorade Frost (blue) mixed with half water – WHEW!
  • WR400inOZ
Posted June 25, 2001 - 07:15 PM
Not only do you guys have too much time, you must have too much money to spend on all this aftermarket stuffo !! :)
You guys over there have the best access to all of these accessories. I've found you really need to serach hard here in Oz to get some of that good stuff. The only place I have seen a lot of that stuff is from online stores.
  • Mr_Toyz
Posted June 25, 2001 - 08:21 PM
Ok...fine... <nose up, walking away>
99 WR - WR timing, EKN #3, 01 YZ exhaust, Clarke YZ tank, YZ rear fender, IMS YZ seat base, Factory Effex YZ seat foam, Factory Effex graphics and seat cover, Factory Effex Carbon Fiber air box decals, Decal works pre-printed numbers, Moose sticker, RaceTech sticker, ProTec sticker, 3 Factory Effex stickers, GYTR sticker, Cycra sticker, Acerbis sticker, 2 Scotts stickers, Scotts stabilizer, Scotts upper triple clamp, Pro Taper CR Hi's, Trail Tech Panoram computer, Terry Cable hot start, DSP Carbon Fiber upper fork guards, Fastline Steel braided front brake line, Motion Pro Terminator clutch cable, Renthal grips, Cycra Pro-bend hand guards, GYTR triple clamp mounts for hand guards, Moose skid plate, Flatland Racing radiator guards, Flatland Racing odometer spacer, GYTR front disk guard, GYTR plastic frame guards with 3M grip tape, Michelin S-12's, Renthal Groovelite sprokets, DID 520 X-ring chain, TM Designs chain slider, 5.6 Racetech rear shock spring...Arai helmet, Alpine Tech 8 size 9's(blue, white, balck), Red Alpine star socks, Fox knee/shin guards, Fox soft elbow pads, Fox Kidney belt, Mosse XCR Jersey(blue), Moose XCR pants(blue), Moose XCR gloves(grey), 2rd pair Fox Flexair gloves9 grey, 2rd pair Cannondale gloves (yellow), Smith SMX goggles (3 pair), Roko Quick strap, Fox AirFrame chest protector, Ultimate hydration pack, Moose Enduro tool fanny pack...30 ft duct tape(flat), 5 ft safety wire, Super glue, 4 tire patches, Master link, Protec carb tool, Craftsman screwdriver/nut driver thingy, 3 flat screwdriver bits, 3 phillips screw driver bits, 1 plastic holder for my bits, 1 8mm socket w/extension, 1 10mm socket w/extension, 1 12mm socket w/extension, 1 14mm socket w/extension, 2 Motion Pro tire irons, Hex key set, Leatherman Super tool, Small vise grips, Fredette riders wrench, 1/4 inch drive, 8mm wrench, 10mm wrench, 12mm wrench, 14mm wrench, QuickFill CO2 tire inflator, spoke wrench, 1 4mm long hex head wrench, 1 5mm long hex head wrench, 1 NGK CRE8, spark plug holder, and 1 large Rubbermaid storage container for all my gear.
Don’t make me go for my wife and kids bikes….
  • Mr_Toyz
Posted June 25, 2001 - 08:23 PM
Ok...I give yours IS bigger.....
Ok, Mcarp I'll get rid of it. But I want you to know I saved a copy in Word...
  • mcarp
Posted June 25, 2001 - 08:38 PM
Mr Toyz, Why spoil a good thing now?
I'm not asking folks to NOT use them. Just tone 'em down (remove all the BS everyone has or no one will care about)
I guess Bill has a point about folks seeing the mods and emailing that member for advice and if they would buy that mod again. I can see where that would be of benefit.
I like Mike's signature the best. Truly a "custom" bike
  • *mike68*
Posted June 26, 2001 - 02:12 AM
Thanks Mike
  • Bryan
Posted June 26, 2001 - 02:46 AM
Hey MoMilkman! I didn't see mention of your custom ramp to load your bike into your pickup truck! :)
Wasn't it a 2x10 plank? Or do you have another fancy name for it in your list that I didn't see?
BTW: We did the rest of the Rainbow trail over the weekend. The south side is a little different than the North part we did last year. It has some faster sections, some rockier sections and has less off camber narrow stuff. The trail is a bit wider since ATV's are allowed. But I kind of liked that. It made for nice banked turns. It was a gas!
Bryan...
  • MOmilkman
Posted June 26, 2001 - 04:25 AM
You make a very good point mcarp. Im just doing it in the hopes that there will be a limit put on the avaiable characters in your signature line (say 3 lines?)
I guess Im trying to say Im on your side. :)
Hey Bryan glad to hear the south end of Rainbow was fun. I'd like to make it back out next summer and do that trail again. This time the whole thing.
Hey! I sold that ramp on e-bay for $450! I just said it was part of tom hanks escape raft on Castaway. :D
Enduro Heaven Heres my list!Enduro Enginering Hand Guards with MSR brush guards - Pro-Tapers CR-Hi Bend – Powder coated gloss black by Andrews powder coating – Works Connection clutch perch – Lever skins (black) – Applied racing top triple clamp (blue) – Thumper Racing bar risers +1.5 – Sunstar 49 tooth sproket - DID X-ring chain - Terrycable steel braided clutch cable – Motion-Pro throttle cables – ProGrip grips – MSR skidplateDunlop 755 front – Dunlop 739 rear – Hurricane Hannah retro graphics kit including YZ style front fender, YZ style rear fender, YZ style number plate, w/ One industries graphics kit – DSP carbon fiber disc guard – DSP carbon fiber fork guards – KYB carbon fiber stickers for upper fork tubes – WER steering dampner (rebuilt 100 times) – Factory Effects Backgrounds (clear) – Factory Effects 8” Digits (#24) – shock servicing by Tomlin racing – uncorked, took airbox lid off, cut throttle stop and ditched the boat anchor of a exhaust - Works Connection frame guards – Scotts performance Billet Shark Fin – Clarke YZ tank 3.3 gallon – YZ seat w/ One industries Hurricane Hannah retro style seat cover – Works connection rear brake caliper guard – Carbon fiber looking stickers for airbox from Factory Effects – Maxima Filter oil – Grease zerk on steering head – P3 Pacemaker computer for Enduros - UniFilter Air filter – Filterskins by PC racing – Spectro 10W40 synthetic oil in winter 20W50 in winter – stock yamaha oil filterFMF Powercore IV spark arrestor – ProCircuit Ti foot pegs – MSR lower chain roller - Thumper Racing wrap around radiator guards – Spectro coolant – Homemade brake snake – Rejetted from 168 stock to 180 on main – Heavy duty tubes (front MSR – rear Bridgestone) – changed oil every three rides – clean oil filter every 3 rides – took bike to the dunes and tore completely apart and got all sand out and put back together – thinking about getting more cool stuff for it –Fox fanny pack with lots of tools - Helmet Cam from www.helmetcamera.com - Bell helmet Choidi style – Answer Edge chest protector – Answer elbow pads – Alpinestar Tech 8 boots black – MSR gear as follows: 2 vented jerseys (this years model and last) , MSR system 6 pants (this years and last) – Fox Racing Dirtpaw gloves yellow – MSR system 6 gloves blue – No fear socks (black and white) – Moose knee pads (very comfy I might add) – Moose gear bag – Kevco-Stubbs kidney belt – Camelbackstabbers drink system – Scott Goggles clear – Roko quick strap – Smith roll offs – double payne lens- and I have a blue and grey lens too – MSR goggle bag – MSR raincoat – Underwear glove liners – Hanes briefs with skids – Breathe right nasal strip when racing – Gatorade Frost (blue) mixed with half water – WHEW!
