1987 600XR OIL LEVEL
3 replies to this topic
  • DAHGSR
Posted September 06, 2004 - 10:59 AM
How much oil do I put in my 87 600XR? I dont have a manual and how do you check the levels? No dip stick anywhere.
  • don87xr600
Posted September 06, 2004 - 01:53 PM
It takes 2 litres per oil change 2.6 after a rebuild or removing a side case if you let the oil run out. The dip stick is on the bottom of the fill hole cap just behind the steering stem.
  • HeadTrauma
Posted September 06, 2004 - 09:17 PM
You are also supposed to start it up and let it idle for a minute or two before checking the level. I have an owner's manual for an '87 and looked up that and the capacity when I changed the oil a few days ago.
  • MotoChris521
Posted September 07, 2004 - 05:28 AM
The manual says a min or 2 ,but i've found that it has to be run way longer than that.Check it after two minutes,then ride it and check it after 15-20 min.It will be way higher up the dipstick. :thumbsup:
  • 22 replies
  • Hot  186 replies
  • 3 replies
Honda XR650L 2016
  • 0 reviews
