Project 650R STEALTH!
1 reply to this topic
  • Keyser_Zoze
Posted May 25, 2001 - 08:57 PM
As cut & pasted from Yahoo Groups 650R board.
So late last week there were a bunch of posts about the merits of riding a quieter bike while not sacrificing too much power. This was my goal exactly, but I wan't ready to cut up the stock tip because I wanted something to fall back on if needed.
So, with a little help from a friend that works with auto exhaust tuning/testing, I set out to modify the hop-up tip to get it from
about 96dBa to less than 94dBa, which is the requirement that the Michigan DNR and USFS, as well as the CCC will test to.
Here's the written description of the modification - I'm trying to weasel a digital cam to take pictures, but haven't had any luck yet.
Go to your local home improvement store and buy a 1 1/2' chromed-brass p-trap kit (typically used for kitchen sinks). (I found one that was "heavy duty" (17 ga. wall thickness)) Make sure that the straight section of tube with the 90 degree bend in it has at least 7 inches of straight before the bend (not counting any silly ends that you'll cut off).
Cut the end with the 90 degree turn such that it looks like an exhaust tip turn-down, and not a sink pipe. In the end opposite the
bend, drill 3/16" holes thru the pipe spaced about an inch apart on the last 5" of pipe (again, the 5" furthest from the 90 degree bend.) Repeat this driling process around the pipe so that you end up with about 30 holes in that last 5" of pipe.
Take the pipe and load it into the hop-up tip (test fit). It'll fit a little sloppy, because the ID of the tip is about 1/8" larger than the OD of the pipe. Load the (drain) pipe into the jaws of your vice
with the swiss cheese end pointing straight up. Slide the hop up tip on top of it. Adjust the position of the pipe to make the end that looks like swiss cheese is within 2" of bottoming on the end cap (the piece that goes inside the muffler and is attached to the S/A Screen) of the hop-up tip. Make sure the pipe is centered in the hop-up tip, and turned the right way so that drain pipe will point down when installed in the Pig. Get everything just right, 'cuz it's time for
the modern day wonder-- J-B Weld! Give the inside of the hop up tip a squirt of brake cleaner (or other suitable enviro-friendly
solvent), mix up a batch of J-B Weld, and smear it on the pipe where it will come into contact with the outlet of the hop up tip, then set the tip onto the pipe and let it dry over nite.
The result is a pretty clean looking exhaust tip with a turn-down that flows pretty close to the unmodified hop up tip (I didn't need
to change any carb settings), tests at just under 91 dBa, cost less than $20, and took less than 45 minutes of time to make.
Sure, there are other solutions out there (Bill, the Baja Baffle is nice (my buddy's got one on his WR-tests at 93 dBa)), but my wife won't ask about the Home Depot receipt and she'd surely notice another box of motorcycle parts from the UPS guy! And I still have the stock tip to fall back on when the CCC says I have to have a tip that says "arrestor" on it even though the DNR and USFS told me that's not a requirement!
If anyone wants more details while I'm trying to find a camera, give me a message off list and I'll fill you in as best I can.
NOTE: I am going to try this over the weekend and post my results!
[This message has been edited by jpeters (edited 05-26-2001).]
  • Toe-Nee
Posted June 21, 2001 - 05:03 AM
I'm into "STEALTH" riding too. I would be interested in seeing your baffle mod when you get a picture of it. I cut the center pipe out of my stock baffle on my 650, and am planning to weld an elbow to the end of it. I did this years ago (welded an elbow to the stock baffle) on my 85 XR350 and dropped it by 4db.
Tony (you wont hear me coming) Weese
1993 XR600R rebuild by ove
  • Hot  41 replies
  • Hot  28 replies
  • Hot  35 replies
  • Hot  60 replies
  • Hot  32 replies
