Shifting problem 02 YZ426.
2 replies to this topic
  • WileE1
Posted September 05, 2004 - 08:46 AM
a few weeks ago i cased a tree on the shifter side of my bike. Since then I have had trouble with the shifter getting stuck between gears when shifting up or down a gear.
I keep the oil changed often. However, the last oil change, I switched over to Motul 5100 10/40 synthetic.
Ive got about 400 miles life to date on the bike.
Should I be concerned. Just wondering if I will have to split the case. :thumbsup:
  • Hick
Posted September 05, 2004 - 03:35 PM
You may have bent the shift shaft, this can be checked/replaced w/ the motor still in the bike, but you will have to take the clutch out.
It is also possible that you bent a shift fork, but it is more likely the shaft or something else in the external (outside the tranny) shifting mechanism.
Hope this helps.
  • WileE1
Posted September 07, 2004 - 05:35 PM
Thanks for the direction Hick. Its worth taking a look at.
How about that Motul anyone using it? Likes, Dis-likes?
  • 5 replies
  • Hot  47 replies
  • Hot  30 replies
